73 280 sel 4.5 starting problems - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-11-2007, 12:25 PM Thread Starter
Date registered: Feb 2007
I recently took on the project to get this car running. It had been sitting for years. the tank had been drained, but not cleaned, and the fuel pump got all glogged up with junk. I cleaned the pump, and got the car to run. but a day after it sterted running it died. We pulled the fuel tank and had it cleaned at a radiator shop, purchased a new pump at a local auto parts store (not a basch pump, but the pump is said to be spec'd for the car) I blew the lines out with compressed air, and pulled the injectors, blew them out with carb cleaner, and compressed air from both ends, and installed new hoses and clamps for the fuel rails also making sure that they were clean. the car will start and run for a few seconds if i pour fuel into the intake, but otherwise does not want to start.
does it metter which way the plugs go into the injectors? I noticed that they are beveled on one side, but sometimes that beveled side is down, and sometimes it is up.
is it possible that in blowing the lines out with air could have damaged any of the pressure regulators, or the cold start valve?
are there any aftermarket pumps that are acceptable for use in this system?
would a plug upside down ruin an injector?
any help would be much appreciated. I bought a book for this car, but it is a bit vague on the electronic fuel injection system....
Thanks in advance!!!
johnnyfaber is offline
post #2 of 2 (permalink) Old 02-12-2007, 09:02 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 16 Post(s)
First,place all the injector wires on correctly i.e. beveled edge to beveled edge. You have D Jetronic BTW
Did you replace the injector O-rings too?
Then go here for troubleshooting
Nutz 4 Benz is offline
    Stored 1993 S420 has fuel problems-Gives sudden starting problems-solution needed heartmd W140 S-Class 15 12-09-2007 01:45 PM
    1984 280 SE Euro starting problem turnip W126 S,SE,SEC,SEL,SD,SDL Class 8 02-28-2006 01:01 AM
    Starting Problem on 280 SEL dilanja W126 S,SE,SEC,SEL,SD,SDL Class 7 01-13-2006 09:24 PM
    280 SEL 4.5 startup&running problems Saabin314 Vintage Mercedes-Benz 4 04-29-2005 04:43 PM
    anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 10:57 PM
