electrical problams - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-10-2007, 12:40 AM Thread Starter
Date registered: Jan 2007
electrical problams
I have a 1971 220d I bought a brand new battery and brand new alternator and it still wont keep a charge what would i be looking for to fix this problam
workinmandan2936 is offline
post #2 of 4 (permalink) Old 02-10-2007, 02:12 AM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
You will have to look for a steady current drain when the car is off.
1. Disconnect the batttery negative cable and measure the total current. This is done by using an ampmeter, in a DVM or VOM.
2. Reconnect the battery.
3. Pull each fuse and measure the current drain. Compare this with the total current drain you measured at the battery.
4. When you find the fuse with the most current, or total current, drain, look at the devices on that circuit.
5. Isolate the loads on that circuit.
You may find that the trunk light is on when the trunk is closed or a new radio is wired improperly or an additional amplifier is wired to be on all the time.
Additionally, if you did add a high power amp, the current draw is more than the alternator can handle and the battery is supplying the current to run it, along with the alternator, and the battery is not being charged.
Make sure the battery clamps are clean.
wbain is offline
post #3 of 4 (permalink) Old 02-10-2007, 07:53 PM Thread Starter
the car does not have a radio in it and it dont drain untill i drive the car i was told that the voltage regulator might be bad, i am new to these cars and dont know where it is and i cant find one in the local parts store. does any one have a pic where it is and what it looks like.
post #4 of 4 (permalink) Old 02-10-2007, 08:41 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 751 Post(s)
In stock -- $39 if you need one.
GeeS is offline
Electrical HELP Rob B W123 E,CE,D,CD,TD,TE Class 0 11-12-2006 06:30 PM
Electrical Kevin Van Caster W140 S-Class 4 01-25-2006 05:10 AM
electrical 96 s class W140 S-Class 18 01-11-2006 10:43 PM
Electrical help AMJ W201 190-Class 1 11-07-2004 09:22 AM
electrical Q Ratso W163 M-Class 2 01-13-2003 07:51 AM
