Coolant? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-02-2007, 03:10 PM Thread Starter
Date registered: Jan 2007
Coolant?
I have to do a coolant flush on my 72 sel 4.5. How many gallons does the radiator hold? Is there another coolant that is as good as the mercedes coolant?
dap019 is offline
post #2 of 3 (permalink) Old 02-03-2007, 06:34 AM
Date registered: Jan 2004
Quoted: 34 Post(s)
Zerex G-05. It likely holds 9 or 10 quarts. One gallon may not get you quite at a 50/50 mix.
Len
sokoloff is offline
post #3 of 3 (permalink) Old 02-03-2007, 03:14 PM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 70 Post(s)
MB manual commands that cooling system contains apprx 13.5 litres = 456.49 liq.oz (US) = 3.57 Gallons (US)
Radiator only contains far less but I believe you meant for whole cooling system.
With regards to coolant mixture, here's MB recomendation (check the attachment file)
Djenka018 is offline
anyone tried Prestone/other 5 yr Coolant (instead of the Benz Coolant) heartmd W140 S-Class 6 11-17-2007 09:28 AM
Time for coolant change - which coolant? oberoi R170 SLK-Class 10 11-13-2006 02:51 PM
coolant again pauljc W126 S,SE,SEC,SEL,SD,SDL Class 2 11-09-2005 02:36 PM
What does a coolant leak smell like with MB coolant? pcmaher W140 S-Class 3 09-27-2004 11:47 AM
Coolant Bisaya W163 M-Class 3 10-11-2003 07:46 PM
