Replacement Fuses - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-02-2007, 12:26 PM Thread Starter
baker462's Avatar
Date registered: Jan 2007
Vehicle: 1973 280C
Replacement Fuses
It's me again! (lol)
I have been told by a few that I should change my fuses, and clean the connections.
Well, at looking at the fuses, they all seem to be intact (non broken) but they also look very brittle!
I am worried if i try to take one out so that I can take it to Canadian tire (automotive store) it may break, and then my luck is that they wouldnt have any replacements! ( so i would be SOL!)
any tips here?
Thanks in advance,
baker462 is offline
post #2 of 4 (permalink) Old 02-02-2007, 12:42 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Just buy the fuses first. They are simply known as "ceramic fuses" in the industry and they are color coded: red = 16a, white = 8a, blue = 25a.
GeeS is offline
post #3 of 4 (permalink) Old 02-02-2007, 01:42 PM
Mogasaurus's Avatar
Date registered: Jan 2004
Vehicle: '78 Mog 416.141 DoKa
Quoted: 54 Post(s)
Beware of large-box auto parts store versions of those fuses. The bodies are made of hard plastic and the end caps are very low quality. Last time I went looking around Chicago, I was unable to find 'real' ones...
Try spinning the fuse around in the spring-clip holder a few times to wipe the oxidation off. You may want to bend the spring clips a little closer together to get more contact pressure. Also, try putting some conductive grease (tiny bit) on each end. Spin them a few times to get a good contact and the grease will keep the oxidation away for a while.
1978 Mog 416.141 DoKa
1971 W113 280SL
..the road to nowhere. . .leads to me.
Mogasaurus is offline
post #4 of 4 (permalink) Old 02-17-2007, 09:33 PM
Sevag's Avatar
Date registered: Feb 2007
Vehicle: 190e Sportline (white); 190e Sportline LE (black)
Get the glass ones. Buss makes the GBC versions, in non-torpedo shape. You can still get them to fit, even though the fuse holders are female (have round holes in them). They will still stay in place, even though your car vibrates during operation. And they last a lot longer than the ceramic ones (even ones made by Bussman or Littlefuse). Btw the glass GBC ones I have are made by Littlefuse. The most commonly available glass ones are found on Napa's website, and come in an 'emergency kit'. Let me know if you want a link
Sevag is offline
    Barrel Fuses vs. MB Strip Fuses 94Wagenmeister W201 190-Class 0 09-25-2006 06:09 PM
    fuses Jippi W201 190-Class 2 09-15-2006 07:39 AM
    fuses ianga General Mercedes-Benz 3 05-10-2006 08:08 PM
    fuses 2LiveNDieInLA W201 190-Class 1 01-27-2005 05:56 PM
    fuses xscottyx W201 190-Class 4 09-04-2003 10:18 AM
