how do I lower a 72 sel - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 01-30-2007, 07:03 PM Thread Starter
Date registered: Jan 2007
I have just aquired a 72 sel 4.5 and was wanting to know how i could lower it. approx. 1-2 inches. any suggestions? also, will the air suspesion form a w109 (300 sel) transfer to my w108 (280 sel) body? any help will be greatly appreciated........
dap019 is offline
post #2 of 11 (permalink) Old 01-30-2007, 09:20 PM
wbain's Avatar
Date registered: Dec 2003
Pretty difficult to lower one of them. The rear camber will be off. As for the air suspension, yes, you can reansfer it but there are many extra holes to be drilled and parts swapped, like the front and rear axles. The air pump and associated bits and pieces must be swapped as well.
What's the matter with the W109 that makes you want to dump it, other than rust that is?
wbain is offline
post #3 of 11 (permalink) Old 01-31-2007, 12:49 AM
Date registered: Oct 2005
best way is to turn your hat round backwards and let the air out of the tyres. Mercedes spent alot of money designing that car. 2 hours with a grinder or cutting torch will not improve the ride.
cargibbs is offline
post #4 of 11 (permalink) Old 01-31-2007, 05:20 AM
Jackasic's Avatar
Date registered: Jul 2005
Vehicle: 72 280SEL 4.5(airbagged), race cars:88 560 SEL, 74 SLC, 67 200, daily: 99 C43, 06 E55 wagon
despite the naysayers, you can cut the springs since they are liner. Also, you can swap over an air ride set up and get a controller from an aftermarket source (but spendy). I "believe" that you have to swap the front lower a-arms also, not exactly sure on that.
You can buy lowered springs from the SL news letter, but they are a grand. here is the link: Sport Springs I am still researching to see if I can fins another source. Don't worry about the folks who give you the"Mercedes built it perfect, why improve it" line. If that was true, why did they ever build another model?
Performance parts for w126, r/c107, w201, m117, m119, m102, m104 and few other things.
Reproduction 17" Penta wheels coming soon.
Feind Motorsports
Jackasic is offline
post #5 of 11 (permalink) Old 01-31-2007, 01:54 PM Thread Starter
Thanks for the input John. I am about to rebuild the susupension anyway and wanted the car to have a better stance.
dap019 is offline
post #6 of 11 (permalink) Old 01-31-2007, 01:54 PM
tinyelvis's Avatar
Vehicle: 1976 280C
You could put some fat people in it ... har har..
I would replace the springs if you really want to do that - check with companies like H&R, Koni, etc, they probably make something for it.
tinyelvis is offline
post #7 of 11 (permalink) Old 02-01-2007, 10:54 PM
Date registered: Nov 2006
Vehicle: 1976 300d @460k
as a side note i pulled up beside a late model A4. i though to my self "wow that thing is slammed" look at the passengers and all 4 were not under 350lbs.
i dare say the old 76' 300d might have won that drag race
otm646 is offline
post #8 of 11 (permalink) Old 02-02-2007, 04:47 AM
Jackasic's Avatar
they don't, although koni does make shocks to fit. better deal than buying Bilstien HD's, since there are no sports that fit.
Feind Motorsports
Jackasic is offline
post #9 of 11 (permalink) Old 02-02-2007, 09:53 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
[QUOTE=tinyelvis]You could put some fat people in it ... har har..
I have an ex wife you could use in that regard!
Grubeguy is offline
post #10 of 11 (permalink) Old 02-05-2007, 05:50 PM
benz280se's Avatar
Vehicle: 1974 280se w116, 1986 560sec
your best bet for lowering springs would be to find a newer model car and see if the perches where they sit are the same, then get springs for that car. i was looking for springs for my 77 and 74 280 se and all the shop guys laughed at me cause the cars are so old they dont have them in their database, but i found a number of the newer models where the springs are an exact fit. DO NOT CUT YOUR SPRINGS AND DO NOT HEAT THEM to lower it. if you heat your springs it will lower them but the metal becomes brittle and could snap. if you cut them you decrease the load bearing capacity of the spring and your car will ride like crap and most likelybottom out when you hit bumps. go to some junkyards and and do a lot of research youll find what you need.
benz280se is offline
    560 SEL vs. 420 SEL, SEL vs. SEC SkiWithG W126 S,SE,SEC,SEL,SD,SDL Class 17 04-11-2007 05:41 PM
    Just bought an sel .... handling differnce between se & sel Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 3 11-23-2005 07:33 AM
    need 560 sel lower door panel!! killcooler W126 S,SE,SEC,SEL,SD,SDL Class 3 07-22-2005 01:35 PM
    Questions 420 sel vs 560 sel cwest W126 S,SE,SEC,SEL,SD,SDL Class 30 06-08-2004 05:26 PM
    Suspension: To lower or not to lower Big D W126 S,SE,SEC,SEL,SD,SDL Class 2 03-23-2004 08:35 AM
