how do I lower a 72 sel - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 02-05-2007, 06:39 PM
Date registered: Oct 2005
Vehicle: '82 380 SL, '82 300TD, '85 500SEC
Originally Posted by dap019
I have just aquired a 72 sel 4.5 and was wanting to know how i could lower it. approx. 1-2 inches. any suggestions?
If you are going to be rebuilding the suspension, your most bang for your buck (free) will be to cut the springs. Americans have been cutting springs since hotrodding was born; and, despite the admonishments of some...there is only one drawback: unlike a haircut the spring length won't grow back. Use a cut-off wheel in an air tool and it'll slice the end off like a butter knife. It will not create enough heat to become an issue worth capitalizing. Also, you can use a soaking wet rag on the "to-be-saved" part of the spring and it won't get hot at all. Use the tool to grind off any jagged edges, especially where it will fit into the mounting donut.
Take 1/2 of the top round off each front and rear spring and re-install them. Let the car settle by driving it for a bit and re-evaluate the height adjustment you've made. The good news is you'll have a lower stance...the bad news is you will introduce some negative camber...and the admonishment about bottoming out will eventually come into play.
Keep taking off 1/4 rounds till the car is suitably cool looking. This trial and error method will make you a suspension-putting-together expert. Another approach is to fill the wheelwells with higher aspect ratio tires. You may end up mixing and matching spring cutting with tire sidewall height changes til you get it where you want it. It is...afterall...up to you.
Tomorrow we'll discuss more ideas your dad will not like.
daveward is offline
    560 SEL vs. 420 SEL, SEL vs. SEC SkiWithG W126 S,SE,SEC,SEL,SD,SDL Class 17 04-11-2007 05:41 PM
    Just bought an sel .... handling differnce between se & sel Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 3 11-23-2005 07:33 AM
    need 560 sel lower door panel!! killcooler W126 S,SE,SEC,SEL,SD,SDL Class 3 07-22-2005 01:35 PM
    Questions 420 sel vs 560 sel cwest W126 S,SE,SEC,SEL,SD,SDL Class 30 06-08-2004 05:26 PM
    Suspension: To lower or not to lower Big D W126 S,SE,SEC,SEL,SD,SDL Class 2 03-23-2004 08:35 AM
