Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-30-2007, 01:05 PM   #1 (permalink)
Blu-spot's Avatar
Date registered: Nov 2006
Vehicle: 1972 280SE 4.5
Send a message via Yahoo to Blu-spot
cold start question
on my 72 280SE 4.5, i want to check the cold start system. i know its not working, but before i spend money on the cold start injector, i want to see if the problem is not the temp sensor that controls it. can i just hook up a voltage meter to the injector leads to see if its getting voltage when its cold while cranking?
Steelies with caps and sealed beams RULE!!
Blu-spot is offline   Reply With Quote
Cold Start/Hot Start/Idle joesette W124 E,CE,D,TD Class 6 01-01-2007 08:18 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL Class 7 01-02-2006 06:33 AM
Question about cold start sputtering kweyer R170 SLK Class 2 04-21-2005 07:23 PM
Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 06:51 PM
Question about cold start idling speed 92W201 W201 190E, D-Class 5 12-15-2004 10:32 AM
