Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-29-2007, 09:03 PM   #1 (permalink)
madmanmerc's Avatar
Vehicle: 1970 280c, 300e amg
vacuum tubes i think
i was just pulling out the seat on my 280c (74) and i noticed that there is a bunch of blue tubes running all under the carpets. some even go to the seats. what are these. if i pull them off will they affect the performance of the car. any advice will be greatly appreceated. thank you
madmanmerc is offline   Reply With Quote
Old 01-30-2007, 07:19 AM   #2 (permalink)
tinyelvis's Avatar
Date registered: Jan 2007
Vehicle: 1976 280C
Yep, they are vaccum tubes. They attach to the diaphrams on the bottom of your seat - mine are long since non-functional, but I think they allowed for easy pushing of the seat forward so passengers could get in the back seat easier. No big deal, a purist would probably want to fix it, but I'm too busy driving mine to care.
I just capped off the lines to be on the safe side, you really don't want any vaccum leaks if you can avoid it.
Good luck!
tinyelvis is offline   Reply With Quote
Old 01-30-2007, 07:49 PM   #3 (permalink)
madmanmerc's Avatar
but if i disconnect them and leave them like that, will it do anything to the performance. thanks
Old 01-31-2007, 03:41 PM   #4 (permalink)
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC, RHD, Ikonengold 419, pergament 205, 82t km's
Location: Serbia, South Africa, Australia, Jamaica... actualy ROTW!
Blue lines (and blue striped lines) are seat lock lines and are part of the safety feature of your Merc.
When doors are closed (light switch is also vacuum switch) seat backrest is locked into upright position and in case of any collision it will prevent passenger from the back seat flying out right trough your windshield.
Purist or not... it's your choice.
It will affect performace to a small degree since if line is open it will allow more unmetered air to go into intake manifold. If decide to decapitate this feature, sugest to plug it under the hood (and disconnect feed)
Djenka018 is offline   Reply With Quote
wanted: 300d injector tubes siegheil For Sale, Trade & Wanted Items 3 12-18-2006 08:37 AM
14.5-20 inner tubes? Daniel/Maryland Unimog 7 07-18-2005 03:24 PM
grease and torque tubes Fizz Unimog 2 05-10-2005 07:50 AM
subzone snake tubes gidmo Audio & Telematics Forum 0 05-24-2004 09:25 PM
side tubes OEM or manik ?? Iwan W163 M-Class 7 06-23-2002 12:48 AM
