Tranny leak, help! - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-29-2007, 03:10 PM Thread Starter
Date registered: Dec 2006
Tranny leak, help!
I just got back from driving 70 miles through the city, and i noticed my transmission leaking a little bit of fluid, i jacked it up and the transmission is pretty warm. I saw that its leaking from this vent looking thing at the bottom of the front of the transmission, where the torque converter(im assuming) is. Anyone know why it would be leaking from there? And is it bad or will it be okay, my tranny is at half full of fluid btw.
1976240D is offline
post #2 of 8 (permalink) Old 01-29-2007, 04:44 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
The 95% probability given that description is the front-pump seal, particularly in light of the age of the car.
It's an inexpensive part that is very expensive to replace as either the engine or transmission must be removed from the car.
If you must drive it then be sure to keep it topped up with fluid, if you run low it's going to get even more expensive.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 8 (permalink) Old 02-05-2007, 06:27 PM
benz280se's Avatar
Date registered: Jan 2007
Vehicle: 1974 280se w116, 1986 560sec
damn my 74 280 se is leaking from the same place i think. and i just spent 1400 correcting other stuff
benz280se is offline
post #4 of 8 (permalink) Old 02-06-2007, 09:59 AM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Probably would not hurt to try something like TRANS X transmission stop leak in the mean time. Could slow it down?
carnut1 is offline
post #5 of 8 (permalink) Old 12-25-2009, 07:26 PM
Date registered: Jun 2009
Vehicle: 2008 ML320 CDI
same with my 72 4.5 sel. Such a nice car overall --just this leaking problem makes me wanna get rid of it.
tetovari is offline
post #6 of 8 (permalink) Old 12-26-2009, 10:07 PM
These are normal rotating shaft seal age problems.
It is best to do the rear crank and trans front at the same time. (4.5)
Yeah I know it costs.
but these are the cheapest cars on the road over time.
Brian O
bostosh is offline
post #7 of 8 (permalink) Old 12-29-2009, 12:58 PM
leaking atf transmission fluid W108
Hello,
Anyone ever removed the tranny and replaced these seals before? how difficult? where did you get the seals? Can it be done in my garage with 4 jackstands and a tranny lift? thanks
tetovari is offline
post #8 of 8 (permalink) Old 12-30-2009, 02:55 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
Take a look at the online resources portion of the forum - I put up some stuff on the 108's tranny. If there's nothing in there on the rotating seals, I'll dig and find something more appropriate.
Grubeguy is offline
Tranny leak, help! 1976240D W123 E,CE,D,CD,TD,TE Class 2 01-29-2007 03:17 PM
Tranny leak steven g W163 M-Class 11 01-19-2007 11:15 AM
Tranny Leak ...Help! upclsnper W126 S,SE,SEC,SEL,SD,SDL Class 7 02-20-2006 01:23 AM
Tranny Leak ...Help! upclsnper W126 S,SE,SEC,SEL,SD,SDL Class 1 02-18-2006 12:33 PM
Tranny Leak ...Help! upclsnper W126 S,SE,SEC,SEL,SD,SDL Class 0 02-17-2006 07:42 PM
