72 280 SE 4.5 - Fuel Pump Problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-29-2007, 08:54 AM Thread Starter
Date registered: Nov 2006
I need help re: the recent installation of my new Fuel Pump and Relay for a 1972 280 SE 4.5L V8
1) I disconnected battery prior to installation.
2) Installed new Fuel Pump and Fuel Pump Relay.
3) Car will not start.
4) Ran two long wires from Battery to Fuel Pump - Pump engauges and runs.
5) Checked No.4 Fuse on Fuse Box (Fuel Pump) checks out ok!
6) Put back old Fuel Pump Relay (Just in case new Relay was defective) Same results - No power to Fuel Pump wires.
Note: Old Fuel Pump did pressurize when Ignition Key turned on. However, the pressure varied and engine would cut off.
Does anyony know if there is another fuse and/or relay I have have somehow screwed up??
1972 280 SE 4.5L is offline
    1979 280 SE - bad fuel pump Cyberbach W116 S, SE, SEL, SD Class 5 07-28-2006 11:24 PM
    280 wiring for fuel pump ianwatsoni G-Class 3 10-31-2005 12:53 PM
    '69 280 SE 6 cyl fuel inj. pump STRONGMACH Vintage Mercedes-Benz 2 02-01-2005 02:21 AM
    1980 280 E fuel pump relay Mr P General Mercedes-Benz 0 01-29-2005 04:03 PM
    280 GE Fuel Pump Relay Feisal G-Class 3 05-18-2002 05:50 AM
