Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-27-2007, 07:00 PM   #1 (permalink)
Date registered: Jan 2007
Need help changing glow plugs
so i got one of the glow plugs off, im having a bit of trouble getting the others off. The fuel lines seem to get in my way of removing them. Any suggestions if i should remove the fuel lines. and if i do, is there anything i should know befor hand? Thanks
240Dbio is offline   Reply With Quote
Old 02-01-2007, 11:08 PM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 1976 300d @460k
i know for sure on a 76 w115 300d all you need is a 21mm wrench. the fuel lines are spaced so removal is possible. you could buy/make a stubby wrench to fit your application. it is slow, mabie only 15 degrees at a time but they come in and out nicely. some penetrating fluid is always welcome.
otm646 is offline   Reply With Quote
Glow Plugs or Spark Plugs?? Are they the same thing? sudha W123 E,CE,D,CD,TD,TE Class 4 11-30-2005 10:27 PM
No glow in the glow plugs dieselpowered W126 S,SE,SEC,SEL,SD,SDL Class 3 10-21-2005 08:17 AM
Glow plugs Cyberbach W124 E,CE,D,TD Class 9 10-06-2005 11:25 AM
No glow in the glow plugs.... dieselpowered W126 S,SE,SEC,SEL,SD,SDL Class 7 09-11-2005 05:07 AM
Glow Plugs...... Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 6 03-17-2002 01:31 PM
