Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-27-2007, 01:54 PM   #1 (permalink)
baker462's Avatar
Date registered: Jan 2007
Vehicle: 1973 280C
Missing a belt
Hey guys!
Sorry for bugging you again! (like i siad, this is all new to me, so I want to learn!)
again, here is my 1973 280C
there is a belt missing (see pics I have attached)
what does this belt run? and how fast do i need to replace it? and of course, if i need to replace it, what size is it?
thanks again,
baker462 is offline   Reply With Quote
Old 01-27-2007, 02:25 PM   #2 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
That would be your A/C belt. It runs the air conditioning. You only need to replace it when you want your A/C to work.
flyboyike is offline   Reply With Quote
Old 01-27-2007, 05:45 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
The thing on lower left corner on picture 1 and 3 is AC compressor. Lot of people disconnected the belt to the compressor assuming that it is taking lot of fuel to run it, but in my years in CA I never noticed any mileage difference between AC season and heating season.
On some engines that belt double as a drive for water and radiator fan, so it is good to have it in such a case even if you are not using AC.
Judging from the look of the compressor it might be hard to restore it, not to mention that you'd probably have to convert the system to 134 freon.
Good luck.
Kajtek1 is offline   Reply With Quote
timing belt/ chain belt benzpimp W202 C-Class 3 11-18-2005 12:46 PM
"V Belt" as MB calls it or Serpentine Belt 98MBE320 W210 E-Class 6 09-16-2005 03:58 AM
Inspite of Hurricane Katrina, missing Aruba teen is still missing kvining Off-Topic 4 08-31-2005 10:26 AM
Missing V-Belt to Air Pump on '85 SE vissjb W126 S,SE,SEC,SEL,SD,SDL Class 3 03-25-2003 08:31 PM
