» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-26-2007, 12:32 PM   #1 (permalink)
baker462's Avatar
Date registered: Jan 2007
Vehicle: 1973 280C
Is it my battery or the alternator??
hey all.. I am new to this!
here is the secnerio..
I got a 1973 280c the other day. it was running fine.
it has been running and starting fine everyday so far (about 5 days)
I drove it to work at 05:30am thursday and parked it. I just got back and when I tried to start it there was no power! (i verified that nothing was left on, lights etc...)
The weather has been cold. it was -20 to -25 (celceus) for the last 2 days here.
I got a boost, and it started right away. I turned the lights on, and heater and started to drive it.
I made it to the stop lights and had to stop. (about 1km away) when the light turned green, i accelerated, started to make my right turn, and it died!
I got another boost, and kept the heater, lights etc off and drove home fine!
when I got home and turned off the car, i tried to start it again, and there was power, but not enough to start it!
so..
would the alternator be dead?(how would I check this)
would the battery be frozen?
or is the battery just dead? (as in wont take a charge anymore)
any thaughts? where to begin trouble shooting..
Thanks in advance
baker462 is offline   Reply With Quote
Old 01-26-2007, 01:24 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
Could be alternator woes, but check the battery first...
German Star
GermanStar is offline   Reply With Quote
Old 01-26-2007, 01:31 PM   #3 (permalink)
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC, RHD, Ikonengold 419, pergament 205, 82t km's
Location: Serbia, South Africa, Australia, Jamaica... actualy ROTW!
I guess it a simple thing to go to one of the battery retailers and ask them to inspect the gravity of your battery. That test will indicate batt condition and you will know for sureif replacement is needed or not.
At -25Celsius probably only very good batteries would crank for long.
Your batt may be good enough for sunny side of the world but not for Canada weather.
If batt is in decent condition than you may have problem with alternator not charging at all or not charging enough. Again, in Afrika that is a free check by same place that is seling batteries. BTW, sometimes belt that drives alternator causes poor charge (and a helluva sqweek).
Djenka018 is offline   Reply With Quote
Old 01-26-2007, 07:35 PM   #4 (permalink)
baker462's Avatar
Vehicle: 1973 280C
hey all, thanks for the input.
another thing i noticed this evening was this..
when i turn the key, the battery light lights up bright red (engine not running) before actually starting the engine.
once it is started it goes out.. like it should..
if the engine is idleing, the light is VERY dimly lit (just faintly lit) if i give it some gas, it goes out completly. (untill the engine goes back down to idle)
so it seems to me that the rpm's need to be higher for the light to go out completly..
any suggestions now?
Old 01-26-2007, 09:34 PM   #5 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
How old is the battery?
Is the fluid level correct?
Did the battery freeze? If so, get a new battery.
Is there any corrosion around the battery posts?
Is the top of the battery clean?
Are the wire clamps tight and clean?
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 01-27-2007, 04:13 AM   #6 (permalink)
Date registered: Oct 2005
From the symptoms you describe it sounds like a worn alternator. Check the belt condition and tension. Clean the battery terminals with some emery paper. Chances are you are driving around in the dark all the time with radio, heater fan, lights on and your tired alternator is not keeping up with it all.
Good luck and have a nice winter.
cargibbs is offline   Reply With Quote
Old 01-29-2007, 01:35 PM   #7 (permalink)
Here is a post that I did on another board about this very problem. I would be it's the regulator.
Pagoda SL Forums - Alternator & Voltage Regulator Explanation
ctaylor738 is offline   Reply With Quote
Old 01-30-2007, 09:33 AM   #8 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
If your near an Auto Zone, Discount Auto Parts or near equivalent up there in
Canada ( eh? ) they test for FREE
Alternators
Starters
Radiator Caps
Batteries
Run it to them and see what turns up
Its quick and cheap ( free )
Afterwards you'll have to see what your "wallet" says to your mind about
what to do....
Good Luck
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 02-01-2007, 11:00 PM   #9 (permalink)
Date registered: Nov 2006
Vehicle: 1976 300d @460k
Grounds, Grounds check them twice. just take a peek even if you have found your problem. compound failures are possible.
otm646 is offline   Reply With Quote
Battery / Alternator issues jadzuric W201 190E, D-Class 1 02-06-2006 03:41 AM
Battery or Alternator?? Benzola SD W126 S,SE,SEC,SEL,SD,SDL Class 2 11-23-2003 07:33 PM
Battery or Alternator? aerosly W126 S,SE,SEC,SEL,SD,SDL Class 6 08-29-2003 06:10 PM
Battery or alternator? cjscopp W126 S,SE,SEC,SEL,SD,SDL Class 8 05-03-2003 01:26 AM
battery/alternator question Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 01-14-2002 01:10 AM
