5 spd. zf rear tranny mount needed... - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-22-2007, 07:15 PM Thread Starter
67300se5spd's Avatar
Date registered: Dec 2006
Vehicle: 2004 E320
Quoted: 10 Post(s)
A friend is installing a 5 spd. zf tranny into his 68 280 sl but is missing the correct rear transmission mount.....Mercedes doesn't have them anymore....Anybody have one or know of a source.....?
Thanks, 67300se5spd
67300se5spd is offline
post #2 of 6 (permalink) Old 01-22-2007, 07:32 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
280SL manual transmission mount: $36.
GeeS is offline
post #3 of 6 (permalink) Old 01-24-2007, 02:13 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
Ron Does the manual 4 speed DB trans have the same mount as the manual 5 speed ZF trans? If so ,he is asking the wrong people for the parts.
mercmad6.3 is offline
post #4 of 6 (permalink) Old 01-24-2007, 06:43 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
I cannot say for certain. All I know is that I looked it up in the EPC for a manual trans and they only showed one.
GeeS is offline
post #5 of 6 (permalink) Old 01-25-2007, 01:29 PM
Quoted: 17 Post(s)
I have found that with a lot of Mercedes parts lists lately,the same part( what ever is required) can be found on a different model part list,an example is self leveling pumps,I had W114 with rear self leveling .The pump was leaking so the PO sold it to me because Mercedes No longer list a part.Same pump as all the other models ( 114.115.123.126 116 etc etc ).
Another is the center bearing mount.On my 500SEc the mount had failed so I went to my local dealer and asked for a new one,to be told" they no longer list them"..(!!??) .Duh.look under any W126 and it's same part.
Then they told me there was a 6 week delay to get one from Germany.ebay to the rescue.
On the 6.3 there is switch on the intake body which controls the transmission oil pressure when idling in gear.
Again Mercedes say this part is no longer available.Yes it is,it's the same part on W111 ,112,and W113's .and is commonly available for them anywhere.So never take their word for it.
So as far I can see,the parts are available ,we just need to look a bit harder at the lists of parts in other models.
post #6 of 6 (permalink) Old 01-28-2007, 06:00 PM Thread Starter
Vehicle: 2004 E320
Quoted: 10 Post(s)
Thanks for the replies ....
The part needed wasn't actually the mount...it was the rear support bracket ...Sorry ! It is different on the 5 speed ZF than the 4 speed so this is what made it so difficult/ impossible as it turned out to locate. He had to fabricate one from a 4 speed rear transmission bracket in order to get the job done...
what ET needed if mount 19'' wheel on VITO638/639? borbetchina V-Class 2 03-01-2006 12:26 AM
Is the Rear Engine Mount the... Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 2 03-17-2005 07:48 PM
motor and tranny mount problems for 87 560sel shlyd W126 S,SE,SEC,SEL,SD,SDL Class 0 08-15-2004 05:28 PM
**Urgent** Help/Advise Needed!!............my fricken TRANNY went out !!! jay (new jersey) R170 SLK-Class 41 10-16-2003 06:24 PM
engine/tranny swap info needed. Guest (MBNZ) W201 190-Class 0 11-13-2001 09:37 AM
