Transmission swap - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-20-2007, 02:20 PM Thread Starter
Date registered: Dec 2006
Transmission swap
I have a slow automatic in my 240d. Im looking for a manual tranny and im wondering which ones i can use from which different cars, like can you put a manual tranny from a 220D into mine.
1976240D is offline
post #2 of 2 (permalink) Old 01-24-2007, 03:36 AM
Date registered: Jun 2004
Quoted: 6 Post(s)
Bolts right in,but you need to get the 220 as a donor car to retrieve everything from pedal box,mastercylinder,reservoir,pipes connecting hose,new flywheel bolts, new clutch plate,Flywheel etc etc etc etc .Cheaper and easier to fix your trans.
mercmad6.3 is offline
    transmission swap rickscustomz W126 S,SE,SEC,SEL,SD,SDL Class 7 07-21-2010 08:03 PM
    manual transmission swap joef W124 E,CE,D,TD Class 33 08-27-2009 05:10 PM
    300e transmission swap????? Jammerkiller W124 E,CE,D,TD Class 0 03-09-2006 09:12 PM
    Transmission swap dinofast W163 M-Class 1 05-23-2005 10:06 AM
    190DT transmission swap danalinscott W201 190-Class 3 08-21-2003 02:16 AM
