Air Suspension question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-20-2007, 05:43 AM Thread Starter
Date registered: Jan 2007
Vehicle: 1970 European 300SEL
!970 300SEL contiues to settle on the suspension after all four airbags replaced.
No leaks are noted vehicle will settle down between 30 minutes and sometimes a
few hours. Anyone have a clue where to begin the hunt? Regards, Steve
sedgar is offline
post #2 of 2 (permalink) Old 01-24-2007, 03:09 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
It's as simple as looking for leaking air.
Start at the main valve and squirt soapy water on it.then do the same at the three height valves,two at the front and one at the rear.
Then look at the main reservoir under the left front fender.It has a non return valve in the hose between the compressor and tank,then check the three rubber hoses between the main valve and the front axle assembly ( left hand lower side.)
If that is difficult or you cannot find the leak ( I suspect the bags are not seated properly or the steel loines have NOT had the O rings replaced) go to Chris Johnsons site here and see how this airspring expert does it.
mercmad6.3 is offline
    Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 5 07-12-2010 03:30 PM
    Can you change the air suspension from a V-Class to Spring suspension? kimberly General Mercedes-Benz 2 11-16-2006 02:35 AM
    Air Suspension Question. zergcerebrates W211 E-Class 1 06-08-2006 11:00 PM
    Air suspension question. zergcerebrates General Mercedes-Benz 1 05-24-2005 08:03 PM
    Air suspension question. zergcerebrates W211 E-Class 1 05-24-2005 04:11 PM
