coolent overflow tank - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-20-2007, 04:14 AM Thread Starter
Blu-spot's Avatar
Date registered: Nov 2006
Vehicle: 1972 280SE 4.5
Send a message via Yahoo to Blu-spot
dont know if the 72 280se 4.5 evercame with a recovery tank, but mine doesn't have one, and never has so far as i can see......
so I'm walking through wal-mart one day, ok yuk it up, anyways they have a radiator recovery tank kit for like 10 bucks, heavy plastic, metal bracket thingy that surrounds the whole tank, hose, clamps, and mounting hardware. so i get it, think ill try it out as soon as the snow lets up.
Steelies with caps and sealed beams RULE!!
Blu-spot is offline
post #2 of 5 (permalink) Old 01-20-2007, 06:50 AM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 56 Post(s)
unless you have pressurized cooling system, there should be no point in installing oveflow tank. It may be minor change to upgrade.
BTW, why everyone here keep saying coolent but not refrigerant, lubricant etc
Vitamin C for SL... the SLC
Djenka018 is offline
post #3 of 5 (permalink) Old 01-21-2007, 03:58 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Be aware that the new cap that comes with the recovery tank MUST be the same pressure rating! If your original cap is say 14 lb. the new cap must be the same. The heart of the system is the new cap. Thats why you'll find it to have 2 gaskets rather than only 1 as the original cap has. Very worthwhile upgrade but can be done wrong using an improper cap.
carnut1 is offline
post #4 of 5 (permalink) Old 01-24-2007, 02:25 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
I guess new mexico has the same temps as here in Australia,so the recovery tank may be a good idea ...on your chevy.
On a merc such as your 4.5 the radiator has a designed level about 3/4 inch from the seal area in the filler neck,It must have an airgap in the top of the radiator header tank because as the engine heats up the water expands and fills this airgap.
If you overfill the radiator it will push the excess out of the cap.The cap is designed to allow air back in as it cools down again.If not,the hoses will shrink and impede the flow of water.
By installing the header tank you will only be filling the radiator each time the engine cools down as the recovery tank is designed to do,not really neccesary when you think about it unless you have a really hot climate where there is a risk of losing all your coolant all the time.
Install it by all means ,but be aware that the radiator will be overfull all the time.
mercmad6.3 is offline
post #5 of 5 (permalink) Old 01-26-2007, 08:58 AM
Having the radiator "overfilled all the time" is a good thing! The air normally present in the radiator will now be in the recovery tank. You've added maybe a pint to the capacity and no air will be in the circulation. All good things. The prior posters theory is flawed because he didn't take into account the recovery style cap. The new cap will pull coolant, not air back into the radiator. And yes the system is a pressurized type, just read the pressure spec on the old cap. I say again, upgrading to a recovery style system is very worthwhile. just do it correctly with the proper upgraded cap!
carnut1 is offline
    '98 320 loud bubbly noise in coolant overflow tank when the truck is turned off pcy W163 M-Class 10 01-15-2008 10:57 AM
    differential leak or overflow from breather cerritos W210 E-Class 1 09-19-2006 11:45 PM
    Fuel overflow basix W126 S,SE,SEC,SEL,SD,SDL Class 1 12-25-2005 09:05 PM
    gasoline overflow Southin W126 S,SE,SEC,SEL,SD,SDL Class 7 08-03-2003 01:52 PM
    Gas coming out of the overflow heffror W124 E,CE,D,TD Class 3 03-22-2003 09:44 AM
