1976 240D Question - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-12-2007, 11:14 AM Thread Starter
Date registered: Jan 2007
1976 240D Question
Hi All,
This is my first post and I'm wondering if anyone can give me some pointers. I'm looking to buy a 1976 240D, body is pretty good, as are the floor pans and jack points. However, there's no heat. Am I correct in assuming that this might need a heater core replacement? If so, that's about $450-500 right there in parts alone and I'd like some leverage in bargaining on the price. Any help would be greatly appreciated!
jfields is offline
post #2 of 7 (permalink) Old 01-12-2007, 12:33 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Welcome to BenzWorld! It's pretty hard to say why no heat, but a failed heater core seems unlikely, since they are usually replaced only when leaking.
GeeS is offline
post #3 of 7 (permalink) Old 01-12-2007, 01:14 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
The heater valves or cables may be broken. Do the valves attached to the cables on the firewall move when the left and right heater sliders are moved?
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #4 of 7 (permalink) Old 01-12-2007, 01:29 PM Thread Starter
I'll check it out
Going to look at it tomorrow, I'll check the heater valves and cables but I'm probably going to buy it anyway as it's a sweet little car.
jfields is offline
post #5 of 7 (permalink) Old 01-13-2007, 10:12 AM
Date registered: Dec 2006
Vehicle: 1979 240D; 1972 220D
Check your fans too. I believe the 115 chassis has a seperate fan for heat and one for AC. If fan needs replacement, you will learn all too well about the front dash of that ole bear.
If the heater fan does not work you will get heat (when you fix the mono valves) it should "lob" in there at good highway speed by natural aspiration. But if it is real cold (less than 20 degrees F) you need fans. Plus the defroster works best with the fan functioning too.
1979 240D
courting a 1972 220D
ts@brdgstn.com is offline
post #6 of 7 (permalink) Old 01-13-2007, 04:26 PM Thread Starter
Bought it!
Just drove it back from an hour away without a hitch, runs great. Looks like I'll be a regular here in the future! Can't wait to get to work restoring it. Turns out it's actually a '75, what a sweet ride (acceleration is not bad at all).
Thanks all,
jfields is offline
post #7 of 7 (permalink) Old 02-11-2008, 06:46 AM
Date registered: Jan 2006
What did you learn about your 240D heater ?
I also just purchased a clean little 1975 240D, a Texas car with zero rust and rebuilt motor, but the heater blows cold as a stone... the fan works and the heater control valve under the hood operates and gets hot. The hoses from the control valve also appear hot but there is zero heat coming from the heater vents in the dash. Is there a flap that directs air from heat to A/C that could be stuck, or I also saw mention of a seperate electric water pump that feeds the heater in another post... Did the 240D have a seperate pump feeding the heater system ? Any help will be a appreciated. John
jbucking is offline
    1976 Mb 240d Tires 240Dkeith Vintage Mercedes-Benz 4 07-15-2006 10:49 PM
    1976 240D Price? wmccoll Vintage Mercedes-Benz 3 03-21-2006 12:23 PM
    FS 1976 240D mabel For Sale/Wanted/Trade/Giveaway 1 09-27-2005 08:17 AM
    1976 240D Injection Timing wmccoll Vintage Mercedes-Benz 8 02-04-2005 03:59 PM
    Just bought a 1976 240D at auction Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 02-14-2002 08:16 PM
