W108 - No Power to Fuel Pump - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 01-10-2007, 04:56 PM Thread Starter
Date registered: Nov 2006
Angry W108 - No Power to Fuel Pump
Hi,
I need help re: the recent installation of my new Fuel Pump and Relay for a 1972 280 SE 4.5L V8
1) I disconnected battery prior to installation.
2) Installed new Fuel Pump and Fuel Pump Relay.
3) Car will not start.
4) Ran two long wires from Battery to Fuel Pump - Pump engauges and runs.
5) Checked No.4 Fuse on Fuse Box (Fuel Pump) checks out ok!
6) Put back old Fuel Pump Relay (Just in case new Relay was defective) Same results - No power to Fuel Pump wires.
Note: Old Fuel Pump did pressurize when Ignition Key turned on. However, the pressure varied and engine would cut off.
Does anyony know if there is another fuse and/or relay I have have somehow screwed up??
Thanks..
I need to get car running..
1972 280 SE 4.5L is offline
post #2 of 12 (permalink) Old 09-15-2010, 04:28 PM
Date registered: Apr 2010
Vehicle: 1972 280SE 4.5 "Kenyatta" , 1972 280SE 4.5 "Arabian Gray"
Have the same exact problem and out of clues. I'm afraid the pump I just ordered might not resolve the issue...hopefully it does. Anybody with ideas? Were you able to resolve the issue original poster sir?
Car stalled abruptly and now will only turn over and not catch on...enough fuel in system and ignition is fine...symptoms remarkably similar with above!
Thanks in advance.
Sam.
505t is offline
post #3 of 12 (permalink) Old 09-16-2010, 06:58 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 97 Post(s)
You should get short burst of voltage (one second) when first turning key to position 2, solid 12V when cranking, solid 12V when running. Have you checked that?
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #4 of 12 (permalink) Old 09-16-2010, 08:19 AM
Thanks for the reply, I am not too sure about the initial short burst, but I am definately getting the full 12v under cranking. And running wires straight to the pump shows us that its working.
505t is offline
post #5 of 12 (permalink) Old 09-16-2010, 03:06 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Bad connection in the socket maybe?
Grubeguy is offline
post #6 of 12 (permalink) Old 09-16-2010, 03:18 PM
Witek_M's Avatar
Quoted: 97 Post(s)
When pump is running does it develop pressure? Does engine start?
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #7 of 12 (permalink) Old 09-19-2010, 04:31 PM
Fuel pump was faulty. Looked a lot like the original pump as well so I suppose its time had come. Replaced it with an Airtex Master pump and all is well now. Appreciate the feedback!
While messing around with the fuel pump relay I dislocated the cylindrical relay for the cold starting valve and it has been chipped away by the alternator fan. Have no idea whether that will affect it, the base with the connection is still fine, any advice would be welcome.
Sam
505t is offline
post #8 of 12 (permalink) Old 05-12-2015, 11:50 AM
Date registered: Apr 2015
Vehicle: 1972 280SE
I'm having a similar problem on my w108 where I get a short burst of voltage (about 12v) and then the power cuts off. I tested the pump and it's fine and I replaced the fuel filter. The relay works as well. Any suggestions on what to test next?
jazztime is offline
post #9 of 12 (permalink) Old 05-12-2015, 02:16 PM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
This should help a bit, it applies to both 108 and 116
Bill A is offline
post #10 of 12 (permalink) Old 05-12-2015, 04:01 PM
Bill A's Avatar
Quoted: 27 Post(s)
It occurred to me that this might be of help as well
Bill A is offline
    W108 1968 280SE Fuel Pump GreenlandW108 Vintage Mercedes-Benz 5 12-11-2013 04:21 PM
    W108 Fuel Delivery Problems - No Power to Fuel Pump 1972 280 SE 4.5L Vintage Mercedes-Benz 0 01-08-2007 02:11 PM
    power to fuel pump relay-300E rbmbz W124 E,CE,D,TD Class 6 12-03-2006 12:10 PM
    W108 V8 Power Steering Pump 56kabrio Vintage Mercedes-Benz 1 10-23-2006 06:13 AM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 04:44 AM
