W108 - No Power to Fuel Pump - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 05-13-2015, 03:45 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
I've seen folks in the forum jumper over the relay so that the pump runs continuously with the key on, regardless of whether the engine is running or being cranked. Can you rule out bad wiring or poor connections? When I bought my 108, I was chasing bad grounds and cracked wiring for months.
Grubeguy is offline
post #12 of 12 (permalink) Old 05-13-2015, 06:35 AM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
This isn't rocket science, I posted a simple training aid that will describe the circuits that run the fuel supply system and where the relays are. With that depending on your abilities to do diagnosis it should only take an hour to locate and understand the issue. I would attach a fuel pressure gauge prior just to be sure when it is working and not. i used to attach mine to the cold start spray valve as it is the easiest point.
Bill A is offline
    W108 1968 280SE Fuel Pump GreenlandW108 Vintage Mercedes-Benz 5 12-11-2013 04:21 PM
    W108 Fuel Delivery Problems - No Power to Fuel Pump 1972 280 SE 4.5L Vintage Mercedes-Benz 0 01-08-2007 02:11 PM
    power to fuel pump relay-300E rbmbz W124 E,CE,D,TD Class 6 12-03-2006 12:10 PM
    W108 V8 Power Steering Pump 56kabrio Vintage Mercedes-Benz 1 10-23-2006 06:13 AM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 04:44 AM
