» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-08-2007, 01:11 PM   #1 (permalink)
Date registered: Nov 2006
W108 Fuel Delivery Problems - No Power to Fuel Pump
Hi,
I need help re: the recent installation of my new Fuel Pump and Relay for a 1972 280 SE 4.5L V8
1) I disconnected battery prior to installation.
2) Installed new Fuel Pump and Fuel Pump Relay.
3) Car will not start.
4) Ran two long wires from Battery to Fuel Pump - Pump engauges and runs.
5) Checked No.4 Fuse on Fuse Box (Fuel Pump) checks out ok!
6) Put back old Fuel Pump Relay (Just in case new Relay was defective) Same results - No power to Fuel Pump wires.
Note: Old Fuel Pump did pressurize when Ignition Key turned on. However, the pressure varied and engine would cut off.
Does anyony know if there is another fuse and/or relay I have have somehow screwed up??
Thanks..
I need to get car running..
1972 280 SE 4.5L is offline   Reply With Quote
Fuel Delivery problems icedtrip R/C107 SL/SLC Class 1 12-28-2006 03:02 PM
W108 1968 280SE Fuel Pump GreenlandW108 Vintage Mercedes-Benz 3 12-19-2006 11:15 PM
86 190e 2.3 fuel delivery problems reggiestewart W201 190E, D-Class 6 02-21-2006 06:44 AM
Fuel Delivery Problems '84 230E skylooker W123 E,CE,D,CD,TD,TE Class 6 12-07-2005 08:54 AM
Diesel fuel delivery problems 1982_300SD W126 S,SE,SEC,SEL,SD,SDL Class 7 11-01-2004 09:10 AM
