Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-07-2007, 01:56 AM   #1 (permalink)
w108 250se air filter
Hello everyone, great forum.
I was just checking the condition of my air filter today ('67 w108 250se) and for the first time removed both inner segments. Things looked pretty good except for a brown oily sludge right at the bottom. Is this normal?
Not knowing quite what to do, I wiped it out with a towel and put a nominal amount of clean oil back in the bottom...
I did notice that there is a line going from the top of the engine to just in front of the intake manifold; is this designed to deposit oil through the filter so it can collect dirt more easily?
Any info is appreciated..
Thanks,
Benziger
Benziger is offline   Reply With Quote
Old 01-07-2007, 06:24 AM   #2 (permalink)
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2007 GL450
Send a message via Skype™ to lomtevas
That particular six cylinder motor was a foreshadowing of engine technology for the next forty years.
The system you uncovered is the positive crankcase ventilation system and part of that system is a pipe running from the valve cover to the air cleaner. Gases from the motor's interior go through the tube to be burned through the intake.
Oil bubbles up. However, today's drivers use synthetic oils which are much slipperier and thinner, and if that is the kind of oil you are using, then stop. The car requires a natural oil with a specific viscosity for everything to work right. Also, remember that the valves in this car required leaded gasoline to lubricate their metal-to-metal seals with the aluminum head. Unleaded fuel can cause an incomplete seal between the valve and the aluminum head causing oil to spit up into the head and through that tube and unto the intake.
It was a marvel of the time: a six cylinder cast iron block with aluminum head; overhead camshaft and aluminum pistons. You know very well the power output is enormous and the sound and feel of that motor is like a trip to Mercedes storied past. The massive body that engine so easily pulled around was also a nostalgic experience. Truly a tank with a 110 mph cruising speed.
Take care of her.
lomtevas is online now   Reply With Quote
Old 01-07-2007, 08:05 PM   #3 (permalink)
Thanks for your response lomtevas, If she ever sees 110mph i'll be a happy man!
I'm using 20w 50 mineral oil, and high octane unleaded with a small amount of additive every couple of tanks (just 20-30mls of 2-stroke oil as advised by my mecha nic).
You're right, it's certainly an interesting engine. So am I right to deposit some oil in the bottom of the filter, or should I just wait for it to accumulate naturally?
W108 4.5 Manifold Air Pressure sensor Grubeguy Vintage Mercedes-Benz 20 08-19-2006 02:53 PM
FS: 3.2 V6 (etc) OEM air filter, oil filter Mann, Mahle ashman78 For Sale, Trade & Wanted Items 2 06-26-2006 06:49 AM
FS: Rebuilt 250SE Injection Pump/R&Red Cylinder Head/W108 Seats wdb123 For Sale, Trade & Wanted Items 0 06-11-2005 11:53 AM
Engine air filter and cabin air filter life tempoct R170 SLK Class 2 05-03-2005 09:01 PM
Hello, is an open air filter for mercedes slk 200k or 230k?? I mine so a filter, how k&n... devil R170 SLK Class 12 02-04-2003 09:43 AM
