» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-06-2007, 11:12 AM   #1 (permalink)
bscott
Date registered: Jan 2007
need help with 1975 450 se
Regarding a 1975 450 se sedan (w116):
I have one basic, maybe obvious, question: Does gasoline type (octane) affect the car's performance?
Please don't worry about insulting me, as i'm very dumb with cars.
Truth is I want the car to run well and live forever, but I'm currently on a budget, so I don't want to spend too much on gas if it's not necessary.
Thank You,
b. scott
bscott is offline   Reply With Quote
Old 01-07-2007, 07:33 PM   #2 (permalink)
cth
Date registered: Dec 2006
Vehicle: 30+ mercedes
too much octane is wasted. too little hurts the motor.
Buy decent gas consistently and the motor you save will be your own.
Keep the tank more than half full always (unless your doing a clong trip) and listen to how it behaves after each fill up. Buy the same gas from the same place 4-5 times in a row before you switch to a lower grade/place and go back up a notch after two bad results in a row.
Once you've settled on something you like, keep listening. Also, don't forget to get your valves adjusted. That car needs it every few 1,000 miles. Do that "right now" if you don't know when it was last done.
-cth
cth is offline   Reply With Quote
Old 01-07-2007, 07:56 PM   #3 (permalink)
bscott
Thank you.
I'm a new owner and the advice is appreciated.
And thanks for the tip about getting the valves adjusted, I will have that done immediately.
-b.scott
450 sl 1975 purchase jeffdal R/C107 SL/SLC Class 4 08-05-2005 03:28 PM
Checking out a 1975 450 SL -- any advice? jcm108 R/C107 SL/SLC Class 4 12-20-2004 07:15 AM
1975 450 SL motor ahlj02 R/C107 SL/SLC Class 1 09-18-2004 09:30 AM
1975 450 SL F O R S A L E ! ! ! ! Guest (MBNZ) R/C107 SL/SLC Class 0 07-19-2002 05:40 PM
FOR SALE 1975 MB 450 SL Guest (MBNZ) R/C107 SL/SLC Class 5 07-11-2002 06:44 PM
