oil leak - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-04-2007, 11:19 AM Thread Starter
Date registered: Jan 2006
oil leak
I have a 1969 280 se. I have replace the rear oil seal 3 times. I have had it line bored. The last time I replaced it, it lasted about 3 weeks and then started leaking again. Has anyone had a similar experience?
mbzplus is offline
post #2 of 3 (permalink) Old 01-04-2007, 04:57 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
"Repair Size" oil seal
Hi,
Did you use a "Repair size" oil seal? There is a seal available with the sealing lip offset so it dosen't run in the same spot on the crankshaft. The seal can wear a groove in the crankshaft after some time and will not seal properly. They are a dealer item(At least with the M116 and M117 engines)
Tony
3.5 Tony is offline
post #3 of 3 (permalink) Old 01-04-2007, 05:35 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 751 Post(s)
Yeah, not on this car though. The six-bangers use a rope seal in the rear.
GeeS is offline
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
Repair Costs for very slight oil leak at phenolic (sic) oil filler cap, 2001, 320 noelchambers R170 SLK-Class 2 11-05-2005 07:53 AM
oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 03:07 PM
My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 06:21 AM
My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 01:34 PM
