» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 12-27-2006, 12:17 PM   #1 (permalink)
madmanmerc's Avatar
Vehicle: 1970 280c, 300e amg
can this head be repaired
just pulled out the cylinder head thinking all i needed was a head gasket. found corrosion on the head. do these hole looke repairable or should i invest in a new head. thanks
madmanmerc is offline   Reply With Quote
Old 12-27-2006, 12:18 PM   #2 (permalink)
madmanmerc's Avatar
its on my 280c by the way
Old 12-27-2006, 01:50 PM   #3 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
Looks none too healthy to me, but I'd haul it over to a machine shop for an assessment. It should be salvageable if the wall hasn't rusted through...
German Star
GermanStar is offline   Reply With Quote
Old 12-29-2006, 03:43 AM   #4 (permalink)
Date registered: Jun 2004
It can be welded but the chances of it being successful are remote.The head will eaten through in more than one spot,and up where you can't see it will be very thin creating hot spots.Buy a better head.
mercmad6.3 is offline   Reply With Quote
Old 12-29-2006, 05:58 PM   #5 (permalink)
cth
Date registered: Dec 2006
Vehicle: 30+ mercedes
Toss that head and get a replacement. On the side of yours should be a part number, not to mention a compression rating. The compression rating is something like "e x.y". Nothing wrong with getting a higher compression head. -CTH
cth is offline   Reply With Quote
Old 01-01-2007, 11:40 PM   #6 (permalink)
Date registered: Jan 2007
Your aluminum head can be welded & resurfaced if you can locate a machine shop that still does that kind of work. In years past I have see much worse damage repaired. Years ago (late 70's) there was a business that rebuilt aluminum heads. (in the lower San Francisco bay area). They would carve out the damaged area until it could be welded back with enough solid material. I don't know anyone with that skill today. But if you get caught between a rock-&-hard place (with no parts available) you can J/B weld it if the head gasket still covers the water-jacket.
Also -- first check the head & make sure it's not too warped. Measure the thickness of the cylinder head to make sure that you don't shave too much off; there are specs for original thickness & minimum allowable. (and the straight edge measurement is both bottom AND top of cylinder head; so the camshaft won't bind.)
And that valve looks like it is up too far in the head; You probably need new valves.
master: one who is highly skilled.
mechanic: one who repairs cars.
MasterTech is offline   Reply With Quote
Old 01-08-2007, 10:22 PM   #7 (permalink)
madmanmerc's Avatar
thanks
can a scratched rim be repaired? :( 9JR W208 CLK Class 10 02-11-2007 10:53 AM
Heater Box Repaired Ears R/C107 SL/SLC Class 2 10-01-2006 09:03 AM
'84 300D: is it even worth getting the A/C repaired? Brent Turbeaux W123 E,CE,D,CD,TD,TE Class 3 05-14-2005 10:08 PM
Repaired my convertable G-Power G-Class 1 03-12-2005 03:47 AM
Sliding roof ... repaired! AlanMcR W210 E-Class 0 05-18-2004 10:46 PM
