Power Steering Pump & Filter - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-21-2006, 04:35 PM Thread Starter
Date registered: Dec 2006
Question Power Steering Pump & Filter
1969 250 - Got her running and found the steering fluid quite low, really not working when turn to the left, and no filter in the canister. I ordered MB steering fluid and a new filter, but the previous owner must have used regular (red stuff) fluid. Is it ok to mix. The MB fluid is much thicker and closer to clear. I did add some in and it seems to be working fine - now assists left and right. Do I need to purge and refill with just MB?
Lots of other issues with this thing so I would rather move on to the next.
kdsundb is offline
post #2 of 2 (permalink) Old 12-22-2006, 06:34 AM
Date registered: Jan 2004
Quoted: 32 Post(s)
That old red stuff is likely ATF. Mercedes called for ATF in their power steering units until about the late 80's.
Len
sokoloff is offline
    Power steering box and power steering pump thoth_9 W123 E,CE,D,CD,TD,TE Class 7 09-15-2009 07:51 PM
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
    2002 ML 55 Power Steering Pump R&R deezee W163 M-Class 1 10-28-2006 01:39 PM
    Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
    Power Steering Pump bwaymire W124 E,CE,D,TD Class 0 11-30-2005 07:50 AM
