glow plug relay help - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-09-2006, 02:07 PM Thread Starter
Date registered: Dec 2006
Vehicle: 1976 mercedes 240d and 1967 250s
Talking glow plug relay help
could anyone please tell me the location of the glow plug relay and maybe the number of it for a 1976 240D
i cant seem to find it anywhere
thanks
allgoodian is offline
post #2 of 5 (permalink) Old 12-09-2006, 02:22 PM
bigsmooth's Avatar
Date registered: Nov 2006
Vehicle: 1986 S124 230TE
is this a 114/115 model? or a 123 model. if its the latter model, the gp relay should be located behind the driver side headlight. hope this helps.
bigsmooth is offline
post #3 of 5 (permalink) Old 12-09-2006, 03:18 PM Thread Starter
i believe that it is a 114/115 model
post #4 of 5 (permalink) Old 12-10-2006, 01:01 AM
Vehicle: 1976 300d @460k
if it is a w114/115 , i am assuming the configuration is the same as a w115 1976 300D. the glow plug relay is located almost on top of the steering column. remove the lower cardboard trim panel from under the steering column. then remove the plastic steering column cover. the relay sits about 1/2 above the steering column held by a bracket. the wiring diagram and part number is facing you so you should be able to find the part number easily. if you cant read it you could contact german star, they are very good at finding you the correct part number often very, very quickly.
you did not specify your problem but the relay is not often the cause of your possible glow problem. look around this forum and others for many pages of help, or you could message directly and I can personally help you with the trouble shooting process if you cant get a good mental image from others posts.
The offer stands of anyone else having difficulty with their glow plug system
http://www.germanstar.net/
A very good primer which will help you get your head around the relatively simple electrical system:
http://dieselgiant.com/glowplugrepair.htm
otm646 is offline
post #5 of 5 (permalink) Old 12-10-2006, 07:07 AM Thread Starter
thanks a million
you are a great help
Glow plug(s) or glow plug relay...? kavakava W123 E,CE,D,CD,TD,TE Class 16 03-04-2010 07:45 PM
Late Glow glow plug relay smallfence W123 E,CE,D,CD,TD,TE Class 16 10-21-2009 06:33 PM
Glow plug problems, no power to the glow plug relay kbbenz78 W123 E,CE,D,CD,TD,TE Class 8 11-15-2006 08:45 PM
Glow Plug Relay Bratman47 General Mercedes-Benz 0 01-11-2006 06:42 PM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 04:58 PM
