ICU/Tach wiring after Pertronix conversion - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-02-2006, 09:16 PM Thread Starter
Captain Scott's Avatar
Date registered: Apr 2005
Vehicle: 1974 450 SL
Question ICU/Tach wiring after Pertronix conversion
I'm not sure how to wire the Ignition Control Unit after putting in the Pertronix kit? I know it isn't needed, but without certain connections, the tach does not get its signal.
She runs great now, but without ICU being in the loop, I have no tach.
I have seen posts on folks who have successfully made this conversion, but there has been no mention of having to give up their tach. So I assume they have figured out how to wire it up.
Does anyone here know how?
Captain Scott is offline
post #2 of 3 (permalink) Old 12-03-2006, 09:21 AM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 56 Post(s)
Donno for sure but in general if you leave all the connections of original EFI other than those that supply injectors, your revs should work again. Rev metre reads pulses from ignition distributor (or say TDC sensor) and converts it into revs.
Must consult installer of petronix what can you reconnect of old EFI without interferrence.
Vitamin C for SL... the SLC
Djenka018 is offline
post #3 of 3 (permalink) Old 12-19-2006, 11:55 AM Thread Starter
FIxed!
Well, after connecting the wires per the third Pert tech support guy (black to the green tach wire from the ICU and the red to 12v+), it works fine! Tach and all. While I thought I had originally tried it that way, I must have been mistaken. Too bad this isn't the first time it's gone this way...
    85 300D (California) Tach wiring tbakphi22 W123 E,CE,D,CD,TD,TE Class 0 06-16-2006 11:42 AM
    OEM CD/radio conversion wiring harness aucaster W126 S,SE,SEC,SEL,SD,SDL Class 1 04-17-2006 01:54 PM
    xenon conversion for a 2000 ml help - wiring harness help. boomie W163 M-Class 3 01-09-2006 12:01 PM
    Wiring tach and outside temp..... (pics working) MiguelXJ W124 E,CE,D,TD Class 0 12-14-2005 03:23 AM
    Pertronix michael l Unimog 1 07-03-2004 08:47 PM
