Diesel emissions - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-28-2006, 10:20 PM Thread Starter
Date registered: Aug 2006
Diesel emissions
I'm contemplating the purchase of a diesel 220D. They
emissions test diesels in Arizona, USA where I live.
The test is for '30% opacity of the exhaust plume'.
Anyone got any idea how stringent this is? What kind
of things in the engine would contribute to good or
bad emissions and how expensive would this be to
maintain since they have to be tested every year? I'm
not too familiar with diesels.
Gazolba is offline
post #2 of 6 (permalink) Old 11-28-2006, 11:29 PM
Kajtek1's Avatar
Quoted: 1066 Post(s)
Are you sure they smog diesels in AZ?
They never did in CA. I belive the only thing that can make diesel pollute is damaged, or clogged injectors, or bad timing. They can be rebuild by replacing cheap tips only, but tips are not available for all models.
Kajtek1 is offline
post #3 of 6 (permalink) Old 11-29-2006, 12:44 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
I think it was mentioned on another thread that 30% is quite horrible. You'll know it when you go see the car. If it's smoking up a storm at idle that's clearly not a car you'd want to own even if it does pass emissions for AZ.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #4 of 6 (permalink) Old 11-30-2006, 07:38 PM
SakoTGrimes's Avatar
Vehicle: 1964 190D
Diesels of all flavors, were never required to pass emmisions until recently. I doubt anything you could to to an old diesel would make it pass any emmisions test there is, and therefore it is most likely exempt.
SakoTGrimes is offline
post #5 of 6 (permalink) Old 11-30-2006, 11:59 PM
Date registered: Nov 2006
Vehicle: 1976 300d @460k
if she requires testing you just has to meet the specs for the year she was manufactured. my 76 300D would need to meet diesel emmisions stardards for 1976, seeing that it has no emmisions controls i'm assuming they are very lax. michigan no longer tests but if you want to get her in tip top shape you will need to do a molly injector purge, just search the forum, check your timing.
when i has gravity remove my exhaust for me i accidently stood the muffler up on end as i dodged traffic. i noticed a sizable 30 years worth of soot plume out. its worth a good shake if its removed from the vehicle. running on B20 will cut your emmisions by about 15% save for Nox which will remain + or - 2 percent.
make sure she is nice and warm before the test as well
how would a 70's D stack up against a modern gasser on emisions, anyone have any actual data?
otm646 is offline
post #6 of 6 (permalink) Old 12-01-2006, 06:03 PM
Vehicle: 1964 190D
I was considering going through emmisions and asking the guy to pretend my car was an 07 Benz diesel, and seeing if it passes running on B99. Might cost $10 though, more than I can afford right now
    Passed Emissions! Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 10 08-17-2006 11:42 AM
    emissions inspection steven t lee R170 SLK-Class 1 01-29-2006 12:20 PM
    Emissions Experts? niceride W140 S-Class 6 05-07-2005 03:42 AM
    emissions again saporter W201 190-Class 0 01-11-2004 01:40 PM
    Failed Emissions saporter W201 190-Class 3 01-07-2004 04:57 AM
