280c antifreeze in motor - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-28-2006, 10:28 PM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
ok. where to start. havent started my 70 280c in about 6 months. i knew i had a leak in radiator. after 6 months of sitting she started fine. ran for about 2 minutes. turned her off. repaired radiator. after i filled her with antifreeze i tried to start her again. she started for about 2 seconds then stopped. wouldnt start again. i took off the spark plugs and antifreeze came out from the to holes closest to the firewall. could this be something as simple as a head gasket, or could it be much worse. will i have to change the motor. please if you have some real knowledge about these inline 6s let me know what you think. dont want to send it out just yet because im afraid of what i might here. thanks guys
madmanmerc is offline
post #2 of 5 (permalink) Old 11-29-2006, 07:07 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 696 Post(s)
I would assume a head gasket until or unless I saw otherwise.
GeeS is offline
post #3 of 5 (permalink) Old 11-29-2006, 11:26 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Where are you located? I am sure someone can recommend a good repair shop in your area.
Mike
Michael Pillay is offline
post #4 of 5 (permalink) Old 11-29-2006, 05:57 PM
dseretakis's Avatar
Date registered: Nov 2006
This happened to me on a 71 220/8. I thought it was the head gasket but turned out to be a corroded cylinder head. Had to replace with a reconditioned head. The culprit was using water instead of coolant which was common practice in mediterranean countries a while back.
dseretakis is offline
post #5 of 5 (permalink) Old 12-02-2006, 10:32 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
so do es that mean i most likely not have a crack in the core, which is what some mechanic who was trying to rip me off sayed. he didnt even open the motor.
    How many qts of Antifreeze? nikech1 C208/A208 CLK-Class 2 10-27-2006 04:25 PM
    Antifreeze cashieu G-Class 16 03-21-2006 02:44 AM
    MB Antifreeze wv240d W123 E,CE,D,CD,TD,TE Class 4 02-23-2006 11:27 PM
    Help with antifreeze My Self W163 M-Class 6 08-04-2004 08:56 AM
    Antifreeze Jack R170 SLK-Class 2 11-20-2000 10:01 AM
