crunchy brakes - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-16-2006, 05:45 PM Thread Starter
SakoTGrimes's Avatar
Vehicle: 1964 190D
crunchy brakes
1976 300D - My brakes make "crunchy" noise when I stop at low speeds and the car shakes. I have replaced the front rotors and pads but no help. Fluid level is full, cold or hot. Sometimes when I am stopped with the car in drive it will make the crunch noise on and off. If it's in neutral or allowed to creep forward the noise will stop. I had rear brakes checked at Les Schwab and they said they are fine. The brake light has been on ever since I had to ride the brakes down a long hill a few months ago. I am lost on what to do. Help?
SakoTGrimes is offline
post #2 of 3 (permalink) Old 11-16-2006, 05:53 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Maybe a bad caliper?
GeeS is offline
post #3 of 3 (permalink) Old 11-17-2006, 05:23 AM
emashayekh's Avatar
Date registered: Sep 2006
Vehicle: 1971 280S
Had the same crunchy/grinding noise in my '71 280s. When braking I would also get pulled to the right. The front passenger brake caliper was stuck.
You might want to also check the condition of your shocks. A weak shock on one side might cause that too.
emashayekh is offline
    New brakes, new Master cylinder, the brakes are still crap, help! StreekG W123 E,CE,D,CD,TD,TE Class 13 11-27-2009 09:20 AM
    Brakes Question (Changing my Brother in-Laws Brakes, Just to be sure) Donkeykongohio W203 C-Class 3 11-27-2009 09:20 AM
    2003 C230 Sedan brakes to 2004 cross-drilled brakes? aaronmarks W203 C-Class 1 10-05-2005 04:00 PM
    SL500 brakes and e55 rear brakes sonofworf1 R170 SLK-Class 0 08-15-2003 10:24 PM
    Upgrading to Brembo or Porsche brakes? I will buy your W202 AMG brakes from you! Guest (MBNZ) W202 C36 AMG, C43 AMG 1 05-11-2002 02:11 PM
