1972 280SE 4.5L- What does relay behind battery control? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-12-2006, 12:03 PM Thread Starter
Date registered: Sep 2006
1972 280SE 4.5L- What does relay behind battery control?-relay-picture-2-mercedes.jpg1972 280SE 4.5L- What does relay behind battery control?-relays-mercedes.jpgI've been trying to troubleshoot a problem of suddenly not getting 12V to my fuel pump. Several threads made me think it was controlled by the rectangular relay behind the battery. However, from looking at the plug the relay attaches to, there are 6 round slots, and the upper right and lower left (positions 1 & 6) do not have a metal pin sleeve insert. A brown wire goes to #5, a blue with white stripe goes to #3, a purple with white stripe goes to #4, and a big blue and small blue wire goes to #2. If you look at the bottom of the relay that plugs into this, the upper right pin is 87A, the upper left is 87, the middle right is 86, the middle left is 30/51, and the lower left is 85. So, no matter which way you plug the relay in, the 87 pin goes into an empty hole. So, whatever this relay is controlling, I think the circuit is closed until 12V is applied. Therefore, I don't think this is the relay for the fuel pump.
Does anyone else have any experience with this model??
Floydf is offline
post #2 of 7 (permalink) Old 11-12-2006, 12:35 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
It is not a fuel pump relay. It is deemed a "change-over relay' and seems to be for A/C, electric windows, seat belt warning, and/or turn signal. Mercedes number is 000 542 5919.
GeeS is offline
post #3 of 7 (permalink) Old 11-12-2006, 02:39 PM Thread Starter
Same question that I have on my other thread- Any idea which relay might give voltage to the pump? Since none of the wires off of any of the other relays I checked showed continuity to the (+) at the pump, there must either be another device between the relay and the pump, or there is another relay/fuse somewhere that I haven't seen, or there is a break in the wire between the relay and the pump. Any suggestions?? And, do you know if there is a schematic/photo anywhere out there in the vast Internet that I can buy that shows the electrical layout for this vehicle?
Floydf is offline
post #4 of 7 (permalink) Old 12-29-2006, 04:15 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Did you manage to find a schematic for the wiring system? If not, I might be able to help...
Grubeguy is offline
post #5 of 7 (permalink) Old 02-20-2007, 03:18 AM
Date registered: Nov 2005
Vehicle: 1982 300CD , 1972 280SE 4.5L
I could use one. .
I've been trying to find the cause of an intermitent misfire that develops in my '72 280SE 4.5L after running like a dream for a day or two. Initially, it presented as a points problem, so I put in a Petronix ignitor. That first approach had the same result as pretty much everything I've tried (over the past year) since, which is that it appears fixed, then horror as the problem returns.
It goes from champ to chump & back with no rhyme or reason. It seems like a short or component failure, but I've replaced more wires/components than I care to list, & am at wit's end.
As prevalent as these cars are, why can't I find a shop manual? Not something generic, or for a similar model/yr, but this exact car?
caviterruptor is offline
post #6 of 7 (permalink) Old 02-20-2007, 10:51 AM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Have you cleaned/replaced the two sets of trigger points inside the distributor? they, over time get fouled with crankcase oil fumes.
carnut1 is offline
post #7 of 7 (permalink) Old 02-22-2007, 03:02 PM
Yes, I tried that before installing electronic ignition.
Where do I get a good manual/wiring diagram for this car?
    Fuel Pump Relay and pin locations? 280SE 1972 4.5L Floydf Vintage Mercedes-Benz 16 06-04-2016 01:37 PM
    1972 280SE 4.5L car and 1972 280SEL 4.5L parts car for sale benzmeister_WI For Sale/Wanted/Trade/Giveaway 6 09-10-2007 04:38 AM
    Help! Firing order for 1972 280SE 4.5 L Tim Bob Vintage Mercedes-Benz 2 05-08-2006 02:56 AM
    BLOWER MOTER!!!!! 1972 280se 4.5 george tukey Vintage Mercedes-Benz 1 01-28-2005 04:51 AM
    1972 280SE 4.5 Guest (MBNZ) General Mercedes-Benz 0 04-13-2001 09:06 PM
