diesel motor shot, need parts - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-09-2006, 09:29 AM Thread Starter
Date registered: Aug 2006
I have a 1972 mercedes benz 220 d. the car stopped running a few months back and a local mechanic who looked at it reported no compression in the #1 cylinder. He said it might be a burnt valve, but could also be a hole in the piston because when pressuring cylinder he heard air from the oil dipstick tube. does anyone have a good place for finding complete gasket kits for these motors. I have replacement parts but can't find any parts supplier except for my local mercedes dealer for the gaskets. Also does anyone have ideas of what may have caused this piston to burn a hole. Oil pressure and temp were ok at time of incident.
seid is offline
post #2 of 5 (permalink) Old 11-09-2006, 02:45 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
A 1972 220D is not a W123, but a W115, so I'm moving this to the Vintage Forum. Hopefully, you'll get a better response there.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #3 of 5 (permalink) Old 11-09-2006, 02:50 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 542 Post(s)
We might have some stuff for it. Justy PM me a list and I'll let you know.
GeeS is offline
post #4 of 5 (permalink) Old 11-11-2006, 08:46 PM
Date registered: Jun 2004
Quoted: 17 Post(s)
Get a copy of Hemmings Motor News. Many parts suppliers advertise there. Have you tried places like NAPA (not ones like Autozone or O-Reily)? A search on the web should definitely come up with possibilities as well.
As far as the low compression, it might just simply be wore out and needs rebuilding. I would be extremely surprised if there was no compression at all in a cylinder. Surely he checked it with the valves closed. Did he check to make sure the valves were adjusted correctly? I doubt there is a hole in the piston. Could also be broken rings in that cylinder.
KCM is offline
post #5 of 5 (permalink) Old 11-11-2006, 08:54 PM
white500se's Avatar
Date registered: Feb 2005
Vehicle: '80 500SE AMG '80 300SD '78 450SLC '00 Passat GLX Wagon
No offense, but why go to all the trouble and money for a 220D? Hell, when mine died I gave it to charity. Still see it now and then but I certainly don't miss it, downright dangerous the way it accelerated, or rather didn't.
'80 500SE Euro '5.0 AMG'- 5.0 AMG engine, Gleason rear diff (still trying to find the ratio) and full aero kit. Stock interior. BBS RS133 8x16 3 piece wheels with Michelin XGT Z4 245/45-16 tires.
'78 450SLC milan brown metallic/bamboo leather
'80 300SD
white500se is offline
    antenna motor replacement parts... cbjukraine W123 E,CE,D,CD,TD,TE Class 3 08-06-2006 06:39 AM
    Free Sun Roof Parts! including motor etc Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 12-06-2005 10:39 PM
    81-85 turbo diesel motor djz57 W126 S,SE,SEC,SEL,SD,SDL Class 2 07-02-2004 05:24 PM
    617 diesel motor fuel issues mserpe G-Class 2 05-28-2003 01:20 PM
    300GD conversion to turbo-My diesel is almost shot. Big Red G G-Class 3 02-14-2003 01:14 PM
