altitude change - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 11-08-2006, 11:03 PM Thread Starter
Date registered: Oct 2006
altitude change
just drove my 71 250 from sea level (mazatlan mexico) to 7,000 ft (patzcuaro). losing power and stalling at idling. adust the dual carbs and what else? thanx, edward
ednlyn is offline
post #2 of 16 (permalink) Old 11-09-2006, 05:06 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
That's about it.
flyboyike is offline
post #3 of 16 (permalink) Old 11-09-2006, 03:32 PM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 56 Post(s)
Talking of devil, how to adjust for high altitude for minimal loss of power?
By-yhe-book lean and loose a lot of power, a bit richer or a bit leaner?
What about ignition angle?
TNX
Vitamin C for SL... the SLC
Djenka018 is offline
post #4 of 16 (permalink) Old 11-09-2006, 03:52 PM
Date registered: Nov 2006
Just a bit richer
just make it more advance. is better
Grandy is offline
post #5 of 16 (permalink) Old 11-09-2006, 03:54 PM
flyboyike's Avatar
Quoted: 69 Post(s)
By-the-book lean and loose a lot of power, a bit richer or a bit leaner?
TNX
Little bit leaner, if possible. This is somethig we deal with quite a bit with airplanes. You always lean as you climb. Ideally, you want to end up at the mixture setting that will give you slightly below-peak EGT (Exhaust Gas Temperature). With a car, I'd see what the power is doing and how smooth things are and try to keep things that way.
post #6 of 16 (permalink) Old 11-09-2006, 03:54 PM
Try to adjust the Ignition Distributor make it more advance.
adjust the fuel little bit rich
Grandy is offline
post #7 of 16 (permalink) Old 11-09-2006, 03:56 PM
adjust ignition more advance, smaller gap of spark plug 0,7mm
adjust the fuel more rich.
Grandy is offline
post #8 of 16 (permalink) Old 11-09-2006, 05:57 PM
Djenka018's Avatar
Quoted: 56 Post(s)
isn't leaner = hotter?
Will consider havin exhaust temperature measured.
What the optimum temp could be/ where to enquire 'bout temperature?
____________________________
My mech had it set on a bit richer for two reasons (as per him, based on my case):
When a bit richer but not as for sea level (idealy as half the altitude to where I live - 1600m) the car will have overall good performance wherever I travel.
He claimed: richer = no burned valves risk @ sea level, more performance when @ sea level, smoother idle + low revs performance at altitude.
80% of my driving is <3000rpm
post #9 of 16 (permalink) Old 11-09-2006, 05:59 PM
flyboyike's Avatar
Quoted: 69 Post(s)
Leaner is hotter, yes, so on an aircraft we'd watch the EGT gauge and stop leaning slightly before it peaked.
post #10 of 16 (permalink) Old 11-09-2006, 07:03 PM
Djenka018's Avatar
Quoted: 56 Post(s)
I wish same gauge existed under my hood...
Definitively will see how to apply same on 450 engine... I guess IR sensors can help somewhat to check temperature of gases, combined with CO2 tester.
I worry that if engine set (leaner) for 1600m (~4800ft) that when at sea level it can be so lean that I could burn valves.
TNX
    High Altitude Testing Boardmonger W123 E,CE,D,CD,TD,TE Class 7 05-01-2006 10:17 PM
    dynamic seats at altitude Scoundrl W211 E-Class 1 02-02-2005 07:39 PM
    High altitude idle COOPER W124 E,CE,D,TD Class 2 02-24-2003 08:28 PM
    High altitude NOS ques: BillT R170 SLK-Class 2 09-15-2001 02:18 PM
    Supercharger performance at altitude? Art Gorski R170 SLK-Class 1 07-11-2001 04:27 AM
