73 280 se won't go into overdrive - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-07-2006, 03:22 PM Thread Starter
Date registered: Nov 2006
any suggestions???
darkcircle is offline
post #2 of 3 (permalink) Old 11-07-2006, 03:41 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
You mean kickdown gear right? If so check the kickdown switch behind the gas pedal.
79Mercy is offline
post #3 of 3 (permalink) Old 11-07-2006, 03:57 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
This car has NO overdrive. It is direct 1 to 1 in high gear. if you in fact mean kickdown or passing gear, look at the bushings on the kick down linkage. My 72 280SEL bushing was missing where it attached to the trans, hence wasted motion, no kick down. I found a generic bushing and installed it to restore part throttle kickdown.
carnut1 is offline
    Where is my overdrive? gwgjr29 W126 S,SE,SEC,SEL,SD,SDL Class 20 06-15-2007 09:06 AM
    overdrive? cbjukraine W123 E,CE,D,CD,TD,TE Class 3 09-27-2006 08:09 PM
    Please Help guys! no Overdrive . . . black560sel W126 S,SE,SEC,SEL,SD,SDL Class 6 04-15-2005 02:17 PM
    overdrive 1300L krisinak Unimog 1 01-17-2005 11:35 AM
    overdrive Jock G-Class 2 09-28-2001 12:18 AM
