1972 280SE 4.5L fuel pump now doesn't have voltage-looking for diagram - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-06-2006, 06:43 PM Thread Starter
Date registered: Sep 2006
I have been struggling, one step at a time, to get fuel to my fuel rails again. After replacing the gas filter, fuel filter, fuel lines, fuel regulator, cleaned injectors, and now a tired fuel pump, somehow I've lost voltage to my new fuel pump. The old one would hum and then cut off, but I've got no voltage to the leads now. I have no idea how that happened. I do have the wire taken off of the ignition, but I don't believe that it is in the circuit. And, I'm pretty sure the key only had to be in the 'run' position to get the 12V to the fuel pump.
I've read the link from nutz4benz, but I don't have a diagram that shows where the various pins are at to test the fuel pump relay and fuses. Is there a diagram that is available online somewhere? I've looked at all of the fuses in the engine compartment, as well as the fuse in the driver's foot area, and they look fine. I believe that the fuel pump relay is the one closest to the engine wall, but I'm not sure. And, like I said, I haven't seen a good wiring diagram to help troubleshoot.
Any suggestions?? Thanks again everyone for your assistance!
Floydf is offline
post #2 of 4 (permalink) Old 11-07-2006, 07:01 AM
Date registered: Nov 2005
Vehicle: 180D
Hi, The ECU shuts off the pump after about 3-4 sec's if the engine is'nt running.
Fuel flow really does'nt happen much unless the engine is running ,the pump with regulator will just maintain pressure in the rail(s).You want to expect approx. 28 psi. Hope this helps you.kdm
kdm7005 is offline
post #3 of 4 (permalink) Old 11-07-2006, 07:04 AM
Vehicle: 180D
Also, you might try applying 12 volts directly to pump and continue trouble -shooting from there.kdm
kdm7005 is offline
post #4 of 4 (permalink) Old 11-07-2006, 07:11 AM Thread Starter
I've unhooked the return lines at the ends of the rails and put the hoses into two containers. So, the pressure hasn't built up.
I also removed the last fuel pump and hooked it directly to a battery, and that's how I found out it was not working properly anymore. It would start and then slow down. I now have a new pump.
The problem is that with the key in the 'run' position, when I put a multimeter on the fuel pump, I'm not getting any voltage. That's why I need to find out where/how to jumper or get voltage readings from the pump relay and fuse area under the hood. Another link references various pins, but I don't have a diagram that labels those pins.
Floydf is offline
    Fuel filter before or after fuel pump on 1972 280SE? Floydf Vintage Mercedes-Benz 6 10-19-2006 09:09 AM
    280SE 1972 Fuel Damper, pump, system, Problem? Floydf Vintage Mercedes-Benz 4 10-04-2006 07:57 PM
    No voltage on my SLK230 fuel pump Guyver280z General Mercedes-Benz 3 04-12-2006 10:20 AM
    No voltage on my SLK230 fuel pump Guyver280z Audio & Telematics Forum 1 04-12-2006 08:40 AM
    1999 CLK320 stalls, no voltage supply to fuel pump, any ideas? joclk320 C208/A208 CLK-Class 0 04-11-2005 08:16 PM
