Electrical Short Problem - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-06-2006, 02:48 PM Thread Starter
verdejor's Avatar
Date registered: Aug 2005
Vehicle: 1976 W116, 450SE --- 1981 W126, 380 SEL--- 1972 W108, 280SEL---1963 W111, 200S
FUSE #5 constantly blows.
used for: parking/tail/standing right, licence plate, instrument, hazard warning flasher, shift indicator illumination, side marker lamps
How can I troubleshoot?
Also, my headlight switch : Problem is when I take off the emergency brakes the lights turn off + hard to turn on... will replace the switch..
worried more on troubleshooting what wires are bad..
thanks!
other than that, car is great... gotta change the shifter bushings... they are crumbled...
thanks in advance! will post pics of the car now and the later....
It's not all that, But it's mine.
http://www.cardomain.com/id/verdejor
verdejor is offline
post #2 of 6 (permalink) Old 11-07-2006, 03:26 AM Thread Starter
verdejor's Avatar
headlight switch problem fixed.
waiting on a electrical guru to give me insight on how to troubleshoot my car's constant fuse-blowing problem.
thanks!
verdejor is offline
post #3 of 6 (permalink) Old 11-08-2006, 08:47 PM Thread Starter
verdejor's Avatar
ok. used the relays from my 380SEL and put new fuse. checked signal lights and fuse ok. started "pumping" the brakes and fuse out. Now gotta see if theres a wire peeled, etc... it's a learning process. hope someone will put 2cents and teach a easier way to troubleshoot.
verdejor is offline
post #4 of 6 (permalink) Old 11-08-2006, 08:49 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
Wiring stuff like this is just grunt work. There is no other real solution, hence the lack of responses. Good luck -- I sure hope you sort it out.
GeeS is offline
post #5 of 6 (permalink) Old 11-09-2006, 11:43 AM
Date registered: Nov 2006
Arrow Basic troubleshooting for shorts
Here's two bits from an old retired Electrical Engineer:
1) DISCONNECT both battery terminals LEADS from the battery
2) Switch an Ohmmeter to its lowest scale (most sensitive)
3) Put the black meter probe on the Negative lead that was on the battery (-)
put the red meter probe on one side of the fuse #5 holder (fuse removed)
4) - record the reading: a) before pressing the brake pedal
b) while pressing the brake pedal
5) Repeat for the other side of the #5 fuse holder
YOU ARE LOOKING FOR A LOW READING TO GROUND TO DETERMINE IF THERE IS A SHORT TO GROUND SOMEWHERE THROUGH A WIRE OR COMPONENT.
i.e. I=E/R , I=12volts/your reading=less than the value of the #5 fuse
IF THE VALUE I IS TOO HIGH (and we know it is because the fuse blows) BECAUSE
R MEASURES LOW TO GROUND (-), TRY MOVING AND SHIFTING WIRES (AND LEADS TO NEARBY COMPONENTS) THAT LEAD TO THE FUSE BLOCK WHILE THE OHMMETER IS READING LOW RESISTANCE TO GROUND. YOU WILL NEED A BRICK OR A FRIEND TO HOLD THE BRAKE PEDAL DOWN, WHILE YOU INVESTIGATE.
This is how you start the troubleshooting proceedure.
Timmyray is offline
post #6 of 6 (permalink) Old 11-11-2006, 03:42 PM Thread Starter
verdejor's Avatar
well, thanks for the responses. I pulled the tail light cover off and noticed a wire without protection. (both sides same). I also noticed one of the bulbs was "just there".. (the glass of the bulb not attached to the connector butt)/
I replaced the bulb, and threw some liquid tape onto the wires and no fuse blown yet... hope this worked.
verdejor is offline
    Electrical Short Problem LHall W123 E,CE,D,CD,TD,TE Class 3 08-07-2005 12:22 PM
    Electrical Short? Terabyte W126 S,SE,SEC,SEL,SD,SDL Class 10 05-16-2004 11:18 PM
    Electrical Short in the Rain Problem Samurai1833 W126 S,SE,SEC,SEL,SD,SDL Class 1 07-10-2003 08:54 AM
    Electrical short in the Rain Samurai1833 Audio & Telematics Forum 0 07-10-2003 04:41 AM
    electrical short? ashmead W126 S,SE,SEC,SEL,SD,SDL Class 1 02-04-2003 03:51 PM
