Engine swap for a 108/109 chassis - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-30-2006, 06:12 AM Thread Starter
Has anyone here given thought to dropping the 5.6L from a 560SEC/SEL into the 108/109 chassis? If so, what problems did you find? It seems that replacing the old 4.5L with an alloy block 5.6 (~200lb. less weight) would make sense from a performance standpoint (obviously none of this is for economic reasons!) I was considering it for my '72 280SEL 4.5.
My thoughts were to add a more modern fuel injection control system such as those from FAST. (This is the one that Karl Middelhauve uses for his M-100 conversions).
Anyone have any thoughts???
Mack Griffith
56kabrio is offline
post #2 of 6 (permalink) Old 11-01-2006, 01:46 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 16 Post(s)
Should fit but the transmission will be needed as well. Also the front may ride high with the - 200lbs but easily solved.Speedo is electrical on the W126 versus mechanical on the W108 so you'll need that too.That's all that comes to mind at this moment.
Nutz 4 Benz is offline
post #3 of 6 (permalink) Old 11-08-2006, 04:27 AM
triskaideka's Avatar
Date registered: Jul 2005
Vehicle: '68 280SE (w108), '72 280SE 3.5(w108), '88 560SEL(w126), '97 E50 (W210
Quoted: 4 Post(s)
Send a message via Yahoo to triskaideka
Great idea!
Is it going to fit? The 126 engine looks a tad bit bigger than the 108's engine bay, but unless you slap the thing in there you wouldn't really know. The engine mount would probably have to be relocated. I don't know if this has been done before (126 engine into 108). Then there is the matter of making the original gauges compatible with the later electronic circuitry. Transplant the whole 126 engine and tranny into the 108, balance the prop shaft, adapt it to the 108 differential, hook up the wiring and all the electrical connections. How about the brakes? Would the old brake boosters work with the new engine? If anyone is brave enough to try this, please document all the work you do, because I'd like to be next!
'68 280SE (w108)
'72 280SE (w108) 3.5
'88 560SEL(w126)
'97 E50 (W210)
triskaideka is offline
post #4 of 6 (permalink) Old 12-29-2006, 04:21 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
You can also transplant a Ford 289 engine (Mustang V-8) into these suckers (Benz-philes are probably frothing at the mouth right now). My dad did the conversion years ago, with interesting results. I have tried over and again to get the car into my loving embrace, but Dad refuses to sell it...
Grubeguy is offline
post #5 of 6 (permalink) Old 12-29-2006, 05:51 PM
Date registered: Dec 2006
Vehicle: 30+ mercedes
There's a fellow on mercdesshop.com in the process of adapting a 560 (or was it a 500) to his 111 coupe. The task is similar, but yours would be simpler because the car was already adapted to the larger 4.5 v8. You shouldn't have a problem, presuming you know how to transplant all the electronics for the engine and transmission. A 500 is a simpler motor to work with computer-wise. -cth
cth is offline
post #6 of 6 (permalink) Old 12-30-2006, 01:56 PM
I have a constant challenge
I have a constant challenge with trying to get my 4.5 to get up and go. I have had it tuned by the pro's and they say they just can not figure it out. I have to pump the gas pedal to get fuel to the engine.
I have been thinking about changing the engine out because I love the car but I also love that it is ALL original. I would like to know how it turns out for you if you do change the engine out.
72Benz4.5 is offline
    108-109 vapor barrier fatshot Vintage Mercedes-Benz 5 07-18-2006 11:09 AM
    WTB: 123 chassis for a 2.6 engine swap TheUsed87190d For Sale/Wanted/Trade/Giveaway 0 01-17-2006 07:28 PM
    108/109 rear seat back removal kiaserwil Vintage Mercedes-Benz 1 07-08-2005 07:14 AM
    Engine swap! 603 diesel to 123 chassis! Help! aanderson1050w General Mercedes-Benz 4 05-22-2005 07:25 PM
    Available Parts for W120,108,109,110,111,112,113 Linea Vintage Mercedes-Benz 1 10-20-2004 09:50 PM
