starter turns, engine doesn't - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-29-2006, 05:01 PM Thread Starter
Date registered: Oct 2006
Vehicle: 1978 300D
In a different thread, I wrote:
Very often my car does not start the first time I try -- nothing happens when I move the key into the "start" position. Then, I put the car in neutral and try again. Sometimes this works, but usually I have to put the car in drive momentarily and then back into neutral. Then when I try, it starts right up. What's going on?
Another problem I have that seems to be getting more common is that the starter turns, but the engine doesn't. Fiddling with the gear shifter always seems to fix it eventually. What would cause this?
lightnin is offline
post #2 of 2 (permalink) Old 10-29-2006, 05:08 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Could be a bad bendix and/or ring gear. A close inspection would reveal obvious damage.
GeeS is offline
    1994 E220 - Engine turns but doesn't start FrederickJ Benzworld Site issues forum 1 10-01-2006 09:14 AM
    engine turns over only redbulldog R129 SL-Class 6 09-08-2006 04:37 AM
    110cdi engine turns but won't start petesavi V-Class 3 02-27-2005 09:45 PM
    engine turns over doesnt start please help classic benz W126 S,SE,SEC,SEL,SD,SDL Class 3 04-23-2004 11:07 PM
    300SD - Starter turns w/o key: also: glow plugs Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 02-28-2002 08:30 PM
