starter and transmission - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-24-2006, 07:52 PM Thread Starter
Date registered: Oct 2006
Vehicle: 1978 300D
Very often my car does not start the first time I try -- nothing happens when I move the key into the "start" position. Then, I put the car in neutral and try again. Sometimes this works, but usually I have to put the car in drive momentarily and then back into neutral. Then when I try, it starts right up. What's going on?
lightnin
lightnin is offline
post #2 of 5 (permalink) Old 10-24-2006, 08:03 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 706 Post(s)
Possibly a bad neutral safety switch...
GeeS is offline
post #3 of 5 (permalink) Old 10-25-2006, 05:43 PM Thread Starter
Vehicle: 1978 300D
Where is the neutral safety switch, so I can check it out?
lightnin is offline
post #4 of 5 (permalink) Old 10-25-2006, 06:02 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 706 Post(s)
On the side of the transmission.
GeeS is offline
post #5 of 5 (permalink) Old 10-26-2006, 09:08 AM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Also check the shifter lever bushings, maybe worn, causing slop or play in the linkage.
carnut1 is offline
    starter washerman W123 E,CE,D,CD,TD,TE Class 6 03-08-2006 08:27 PM
    Starter Servord W126 S,SE,SEC,SEL,SD,SDL Class 4 06-28-2004 05:23 PM
    Starter keeps on going and going... mham001 W126 S,SE,SEC,SEL,SD,SDL Class 3 01-19-2003 08:14 PM
    Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK-Class 8 10-07-2002 02:35 PM
    Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK-Class 3 04-26-2002 11:05 AM
