W108 V8 Power Steering Pump - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-22-2006, 06:13 PM Thread Starter
I've got a '72 280SEL 4.5 that needs a power steering pump replacement. I have some manuals that show a puller necessary to remove the pump pulley. Anyone have a source for the factory puller or another type that is suitable?
Thanks
Mack
56kabrio is offline
post #2 of 2 (permalink) Old 10-23-2006, 05:13 AM
I used a pitman arm puller from a local parts store. I had to grind open the tool and thin in out some on the bench grinder to make it fit. Worked like a charm though. The tool needs to be quite thin to fit in between the groove on the pulley so I tensioned it which a wrench (not an impact) then began to tap on it with a hammer a few times, tensioned again and tap. Before I new it the pulley was off the pump.
rmcguire is offline
    Power steering box and power steering pump thoth_9 W123 E,CE,D,CD,TD,TE Class 7 09-15-2009 07:51 PM
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
    Power Steering Pump bwaymire W124 E,CE,D,TD Class 0 11-30-2005 07:50 AM
    Noisy Power Steering Pump AndyFracica W163 M-Class 0 04-29-2004 01:28 PM
    Power steering pump (???) Guest (MBNZ) W201 190-Class 11 02-09-2002 09:06 AM
