High engine idle RPM - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-18-2006, 07:42 PM Thread Starter
Date registered: Sep 2006
Vehicle: 1973 280SE 4.5
Initiall I wanted to check and see if I could trouble shoot a high engine RPM, now the car will not start.
I started the Benz, backed it out of the garage and parked it in the driveway. At that time I checked the connection to the electrical connector in front of the air cleaner and reinstalled it. I then did the same to the electrical connector (it has two wires black & red) next to the tower (behind the distributor). They were both loose, easy to remove but were not apart of a plug so to speak. I reinstall them the same way I removed them. I then tried to start the car and it would not start. I usually get the sound of a relay for about three seconds, now nothing. I pushed the car back into the garage for the night. Now I really need some help.
goodguy2 is offline
post #2 of 2 (permalink) Old 10-19-2006, 04:48 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Please fill out your profile so we know the year type model and engine. Thanks
carnut1 is offline
    squeal & high rpm at idle on cold start RichRocky R170 SLK-Class 3 11-04-2006 11:18 PM
    IDLE got high RPM panjap W202 C-Class 3 09-29-2006 11:42 PM
    Rough Idle and engine hesitation/misfiring at high rpm slingerone2002 W124 E,CE,D,TD Class 5 11-18-2005 07:32 AM
    check engine light, unusual high rpm at idle cabby850 W210 E-Class 2 09-28-2005 09:32 AM
    engine misfire at high rpm and load brian/ont W163 M-Class 4 01-10-2004 02:52 PM
