Engine Swap 230 to 280 or other?? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-18-2006, 06:24 PM Thread Starter
Date registered: Oct 2006
New to Benzworld, HELP, !!!I have a 1966 230 SL, European. it runs, but Not well, looking to find a good used engine. Will a 250 or 280 fit?
Don't get mad, American Engine??
Jade Pagota is offline
post #2 of 3 (permalink) Old 10-18-2006, 07:03 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
No reason at all that wouldn't fit. If the car is in good shape, it would behoove you to repair what you have though...
GeeS is offline
post #3 of 3 (permalink) Old 10-18-2006, 07:44 PM
Date registered: Jun 2006
Vehicle: 1973 Mercedes-Benz 280
You can swap any similar size engine in for another (any six cyl to any other six) and most times you can swap from a four to a six, or from a six to an eight without worrying about space in the bay. The only problem with switching from a Mercedes engine to an American engine is the amount of work you need to do to convert everything in the car to the American system
I have a 1973 280 sedan, and I've thought about switching the 2.8L in it for a Ford 302 5.0. However, it would be over $5000 dollars for all of the necessary parts to do it, not to mention weeks of labor.
My suggestion is to work on the engine in there. Unless there are some problems with the block itself (cracks or poor machining) you can turn that engine around with little problem.
73280Sedan is offline
    swap 320 engine into 230? slk_jason R170 SLK-Class 30 02-23-2015 10:58 AM
    280 Powerplant Swap Question Autobahnfahrer General Mercedes-Benz 1 12-09-2010 09:57 AM
    280 engine swap like for like Gazolba Vintage Mercedes-Benz 5 10-03-2006 03:54 PM
    Engine transplant question - 230 to 280 in a RHD CE Help!! shrimpton W123 E,CE,D,CD,TD,TE Class 8 02-04-2006 01:45 AM
    Auto trans swap for 280 GE Iwan G-Class 0 07-02-2003 12:01 AM
