W114 restore project - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-18-2006, 04:41 PM Thread Starter
Date registered: Oct 2006
I just bought a W114 (280CE) from a scrapyard ... got new keys made by MB.
However I still have trouble opeining the trunk.
The key works, can turn the lock, but the mecanism seems to be blocked.
Can put the key in 3 positions: Horizontally, then 90 deg. clockwise and not quit 90 deg counterclockwise.
Central locking cannot work as the engine is not running.
Any hints?
Oskar is offline
post #2 of 3 (permalink) Old 10-18-2006, 05:38 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Other than just fiddling with the lock, I can't really think of anything. I'm going to move your question to the Vintage forum, maybe someone there will have an idea.
flyboyike is offline
post #3 of 3 (permalink) Old 11-07-2006, 03:12 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 108 Post(s)
i had a similar problem
I had a similar problem in my 71 250CE. The central locking wont work but you can try running air through the vac lines. Don't try to force it because you'll cause more damage then good. The way I got through was through number plate lights.
alabbasi is offline
    240 restore roncor Test 0 11-06-2005 12:57 PM
    Restore this Coupe?? langford Vintage Mercedes-Benz 12 09-06-2005 01:20 AM
    Restore original look radunegru W124 E,CE,D,TD Class 10 03-24-2005 04:31 PM
    Looking to restore my G. Scott G-Class 2 11-24-2001 10:29 AM
    280 - looking for someone to restore Guest (MBNZ) General Mercedes-Benz 0 01-03-2001 06:41 AM
