Running out of gas deadly - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-13-2006, 01:02 PM Thread Starter
Date registered: Oct 2006
My old 1973 280c ran out of gas a few years ago, and after that it began to have trouble starting. I think the carburator and the fuel gauge were messed up somehow. Well, this deterred me from driving the benz over my perfectly working 91 volvo, and I let the 280 sit for long enough for the battery to run out. I haven't looked at it for about two years after the battery ran out, but I'd like to start driving it again.
What could have caused the problems after the gas ran out, and now that it has sat, what do I have to look out for in getting it back on the road?
mgibson is offline
post #2 of 4 (permalink) Old 10-13-2006, 01:59 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Welcome to BenzWorld! Carbs have always been a nightmare on those old 280s. If that's the source of your woes, the only good way out is gonna cost you...
GeeS is offline
post #3 of 4 (permalink) Old 10-13-2006, 03:38 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
The only connection that makes sense is sediment from the tank settled in the float bowl.
carnut1 is offline
post #4 of 4 (permalink) Old 10-16-2006, 04:57 PM
Vehicle: 1973 Mercedes-Benz 280
Can't say I've ever had that problem, but I drive a '73 280 sedan, not a coupe. I've run out of gas several times (unfortunately, with a carburated system, you can't ever quite tell just how much you have left when that empty light comes on) and I've had no problems starting Victoria up, besides the ones that came with the car. The starter's old, as is the coil, and all the wiring.
However, I don't understand how running out of gas would prevent the car from starting or cause you serious, long term problems. Granted, when Victoria ran out of gas I had to pump quite a bit of gas into the engine to get her started, but once that was done, she ran just fine.
73280Sedan is offline
    Spring Perch Problems Could Be Deadly! Raylee177 W210 E-Class 0 08-14-2005 08:29 PM
    Running Rich And Burning More Gas! Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 0 05-31-2005 11:02 AM
    What could running out of gas do to ones car? biffy General Mercedes-Benz 28 01-03-2005 05:02 PM
    Gas running out when cornering Cixi R170 SLK-Class 12 06-30-2004 07:26 PM
    Running a 280 GE on regular gas Patrick G-Class 16 04-04-2002 10:52 PM
