78 300CD - Preglowing - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-10-2006, 09:04 AM Thread Starter
Date registered: Oct 2006
Hi All -
I have a 1978 300CD and I'm experiencing some issues with preglowing. When I insert the key and turn it to the right into the position where the preglowing light would normally come on, nothing happens. This is normal if the car has been running for a bit and no preglowing is necessary, however the vehicle has been parked since last night and hasn't been run since then.
Anyone have any insight as to what could be done to remedy this? I checked the fuse box and replaced the only fuse that was bad, this didn't make a difference, plus the owner's manual didn't indicate that any of the fuses had control over the preglowing.
Thanks in advance!
bornwthatail is offline
post #2 of 7 (permalink) Old 10-10-2006, 09:49 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Could be a bad pre-glow relay.
GeeS is offline
post #3 of 7 (permalink) Old 10-10-2006, 12:27 PM Thread Starter
Update: I called a recommended M-B mechanic in the area and he had me checxk the fuse that powers the glow plugd and relay system. Sure enough, it was shot. I'm going to replace it now and if this dosen't resolve the problem I'll seek further help.
post #4 of 7 (permalink) Old 10-10-2006, 01:02 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Wow -- that's good news!
GeeS is offline
post #5 of 7 (permalink) Old 10-10-2006, 11:58 PM Thread Starter
That did it. One $3 part later and she's up and running again.
post #6 of 7 (permalink) Old 11-02-2007, 09:11 AM
Date registered: Nov 2007
which fuse is that and where do i find it? i am having the exact same problem with my 79 240d
for now i have hooked up a remote starter with the switch in the cab and the wires run to the battery and the preglow control under the hood, when i pull the starter switch the plugs fire up and 10 - 30 seconds later i am ready to start the car. this works every time, but the wierd thing is i dont need it every time, every once in a while the preglow light comes on and it works perfectly. but most times i have to turn them on manually. any thoughts on this.
sorry to jump in to this thread but it seems your problem has been resolved and i am having the same issue. so thanks for any help!
kingdaddy is offline
post #7 of 7 (permalink) Old 11-02-2007, 05:46 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
Was the strip fuse blown or just corroded?
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
    300cd curlycarille W123 E,CE,D,CD,TD,TE Class 1 03-26-2006 11:59 PM
    Value of a 300CD Autobahnfahrer W123 E,CE,D,CD,TD,TE Class 9 11-06-2005 09:53 PM
    value of '85 300cd stro908 W123 E,CE,D,CD,TD,TE Class 5 10-09-2004 09:01 PM
    300CD value Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 6 05-23-2002 01:34 AM
    Hello and 300CD Help... Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 04-06-2002 10:11 PM
