8k Orig mile 71 220d Questions... - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 10-01-2006, 10:02 PM Thread Starter
Date registered: Sep 2006
Vehicle: 1971 Mercedes 220D 8k original Miles!
Ok just got a 71 8k orig mile 220d.
All seems fine but when I got in for the first time I pressed the clutch pedal down.
It was kinda hard so I pressed hard.... It went down and Now it goes up and down VERY easey. I wont come back up unless I move it back up with my foot.
I need to know whats wrong...
THe car has been sitting for about 10 years. Could the Flywheel be frozen to the clutch?
Thanks Much!
Thomas
GermanlookT3(Tom) is offline
post #2 of 16 (permalink) Old 10-01-2006, 10:10 PM
Date registered: Jun 2005
Vehicle: 72 250 M130 W114
Sounds like a broken clutch cable. See if you can trace it. It should reach a leaver that you might be able to operate by hand.
Had a VW golf whose cable went while I was driving. Made it home by sync shifting and at red lights I would turn it off put it in gear and start the engine when the light went green. Wasn't pretty but it got me home.
ggenovez is offline
post #3 of 16 (permalink) Old 10-02-2006, 12:25 AM
Dusty`NZ's Avatar
Date registered: Mar 2004
Vehicle: w115-240D, w115-300D, w201-190e (3), w123-300D w201-190d
Both the clutch master and slave cylinders are probably toast.
Moisture absorbed from the atmosphere , into the hydraulic fluid , will have rotted them , full repair required .
Better check the brakes while you are at it too.
How the heck do you get an 8K car from the early 70's ??? I'm envious.
'76 - 300D
'72 - 240D (noddy)
'40 Chev pickup
Dusty`NZ is offline
post #4 of 16 (permalink) Old 10-02-2006, 10:13 AM Thread Starter
The Guy only drove it around in the summer to and from his work about 10 miles away. He put 5k on it in Germany Just driving it On the Military Base. The other 3 came from him driving to work only from 82 to late 87. After that he would just start it up and drive up and down his driveway.
Back to the Subject...
Im already going to do all the brakes.
So Im gonna look at the Cable and see if its broken I Think its the moisture that got to the Slave and Master Clutch Cylinder. Where could I get those? and Is it pretty hard to replace all that?
post #5 of 16 (permalink) Old 10-02-2006, 10:28 AM
sthu's Avatar
Vehicle: W163/W115
Send a message via Yahoo to sthu
I don't think you have a clutch cable (must be the same as mine and I have hydraulic).
My bet (if not low or no fluid) is that master and/or cylinders are gone. Each unit is about 50 to 100 bucks depending on where you get them.
"de gustibus non est disputandem" ~ No accounting for taste
W163, W115, Matrix
1996 115lb Yellow Lab
sthu is offline
post #6 of 16 (permalink) Old 10-02-2006, 10:32 AM Thread Starter
When redoing the brakes should I get a new master cylinder?
I found the Clutch Master and the Slave Both Under $45
post #7 of 16 (permalink) Old 10-02-2006, 10:49 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
I had this happen with my porsche. I am not sure it will help, but maybe it will. Like I said it was exactly the same situation. First I thought it was the clutch cable. It was not. I replaced it anyway. Fifteen year old cables snap at some time or another. I ended up replacing the pilot bearing, throwout bearing, t/o bearing tube and the clutch fork. The clutch fork was broken. I know it is a totally different car, but maybe it will help you troubleshoot.
Mike
Michael Pillay is offline
post #8 of 16 (permalink) Old 10-02-2006, 10:52 AM Thread Starter
There is no cable for the clutch...
post #9 of 16 (permalink) Old 10-02-2006, 12:34 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
It's hydraulic you'll see the cylinder and metal lines in the firewall. That sure is a sweet find! I wonder what the compression is on it.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #10 of 16 (permalink) Old 10-02-2006, 04:18 PM Thread Starter
Is it pretty hard to replace the Master and slave cylinder?
Also...
Why do you wonder what the Compression is?
orig plugs? kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 0 12-13-2005 06:47 PM
220D Help screwjackfoo Vintage Mercedes-Benz 2 11-16-2005 04:02 PM
1968 220D Questions--Anybody outthere??? Guest (MBNZ) General Mercedes-Benz 2 07-11-2005 10:37 AM
220d chow Vintage Mercedes-Benz 0 06-20-2004 08:13 AM
Is anyone interested on replacement orig...... JohnR R170 SLK-Class 0 04-26-2001 04:27 AM
