8k Orig mile 71 220d Questions... - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 10-02-2006, 05:39 PM
sthu's Avatar
Vehicle: W163/W115
Send a message via Yahoo to sthu
For this age, I will be replacing my brake and clutch lines and recomend to any restorer. There is no short cut (and cheap route) to play with drivability and brakes.
There ought to be two hoses into master cylinder (high and low) and one going into clutch cylinder. There maybe kits for theses (e.g. "O" rings, diaphram) but like I said before, don't play with safety.
Replacements are your basic academic (straight forward).
"de gustibus non est disputandem" ~ No accounting for taste
W163, W115, Matrix
1996 115lb Yellow Lab
sthu is offline
post #12 of 16 (permalink) Old 10-03-2006, 12:18 AM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
Originally Posted by GermanlookT3(Tom)
Is it pretty hard to replace the Master and slave cylinder?
Also...
Why do you wonder what the Compression is?
I jumped subjects, I wanted to know what the ENGINE compression was.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #13 of 16 (permalink) Old 10-03-2006, 02:58 PM Thread Starter
Date registered: Sep 2006
Vehicle: 1971 Mercedes 220D 8k original Miles!
I would guess a little below 24...
GermanlookT3(Tom) is offline
post #14 of 16 (permalink) Old 10-03-2006, 02:59 PM Thread Starter
Has anybody on the forum replaced a Clutch Master and Slave Cylinder?
Is it hard?
Also Is Installing a Master cylinder for the Brakes hard?
Ive done to plenty times with Volkswagen Squarebacks and Bugs... Im shure the Benz should be easeyer!
post #15 of 16 (permalink) Old 10-03-2006, 04:07 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
No, but we've sold plenty of them to car owners like yourself. Swap the clyinders out, bleed the lines there couldn't be much more to it.
GeeS is offline
post #16 of 16 (permalink) Old 10-05-2006, 05:49 PM Thread Starter
Would the Power steering be ok? It uses Hydraulic Fluid? Also
Would the Brake servo? It should be ok right?
    orig plugs? kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 0 12-13-2005 06:47 PM
    220D Help screwjackfoo Vintage Mercedes-Benz 2 11-16-2005 04:02 PM
    1968 220D Questions--Anybody outthere??? Guest (MBNZ) General Mercedes-Benz 2 07-11-2005 10:37 AM
    220d chow Vintage Mercedes-Benz 0 06-20-2004 08:13 AM
    Is anyone interested on replacement orig...... JohnR R170 SLK-Class 0 04-26-2001 04:27 AM
