antifreeze in oil - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 09-27-2006, 10:51 AM
Date registered: Jul 2006
I'm in the middle of doing a valve job and other engine work on my 4.5L. This is not difficult, but certainly is expensive, time consuming and I would not consider it an easy job either. It may be well worth your while to look into a used, serviceable engine to replace yours. This is because it is difficult to contain the impulse of "while I'm there, I may as well replace the following, or have the crank turned and main bearings installed:" and the list never ends. So, what starts off being a replacement for a blown/leaking head gasket, results in a major overhaul because the shop won't warrant any engine with unknown defects, and I can't blame them. My suggestion is to check your local dismantlers and see what kind of deal you can swing. Should you find something of interest, ask them to do a compression or leak-down test before you buy it. The latter being the preferred method. If you are not familiar with this procedure, do a Google on "cylinder leakdown testing" -- there is lots of info on how to do it properly and what the procedure reveals.
Good luck!
nortonfan is offline
post #12 of 17 (permalink) Old 09-27-2006, 11:39 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
I had the headgasket done on my w126. It cost about $1100 or so.
Mike
Michael Pillay is offline
post #13 of 17 (permalink) Old 09-27-2006, 06:09 PM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
actually i was just checking her out.... antifreeze was coming out of the spark plug holes. the 4th and 5th hole from the front. is it still a head gasket
madmanmerc is offline
post #14 of 17 (permalink) Old 09-27-2006, 10:01 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
or perhaps something worse
post #15 of 17 (permalink) Old 09-28-2006, 05:30 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Sounds like you need a head gasket and now rings too.
flyboyike is offline
post #16 of 17 (permalink) Old 09-28-2006, 08:03 AM
engr693's Avatar
Vehicle: 1973 450SL
Must have smoked like the dickens when running. I agree with Ike, definitely need to tear the engine apart and assess all the damage.
Gary
1973 450SL AMG kit installed
1999 Silverado 4X4 Ext Cab
1999 Mercury Sable
1972 450SL - Parts Car - Need anything?
Previously owned keepers:
1967 MGCGT - 3L-6
1972 Mustang Fastback - 351C
Current Cylinder Index: 28
engr693 is offline
post #17 of 17 (permalink) Old 09-28-2006, 08:38 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
wont be happening anytime soon. just bought a house. money doesnt hang around as easy now. i might leave it till next spring. but the bitch is that i just got the carbs rebuilt. if i had known.... i would not have had them redun yet
    Antifreeze cashieu G-Class 16 03-21-2006 02:44 AM
    MB Antifreeze wv240d W123 E,CE,D,CD,TD,TE Class 4 02-23-2006 11:27 PM
    Antifreeze leaking gary1378 W163 M-Class 1 11-22-2005 06:02 PM
    Help with antifreeze My Self W163 M-Class 6 08-04-2004 08:56 AM
    Antifreeze Jack R170 SLK-Class 2 11-20-2000 10:01 AM
