w108 transmission swap options ? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-19-2006, 06:52 PM Thread Starter
Date registered: Sep 2006
I'm enjoying my newly acquired 69 280SE coupe, except the high rpm at highway speeds with the 4 speed auto. I do not want to switch a manual tranny. Are there any overdrive transmissions from later models that would be possible swap candidates ?
rvm67 is offline
post #2 of 2 (permalink) Old 09-24-2006, 05:51 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Put simply...NO. The rare option of five speed tranny had a low ratio diff as part of the package.
Your best bet is to find a 3.5 diff ,and fit the crown wheel and pinion to your diff.that will give a higher ratio.Second best option is to fit 15 or 16" wheels with high profile tires.That will gear up the final drive and reduce the engine speed.But don't forget,the Merc engine does rev all the way to red line,way beyond the speed limit.
This's a Five speed trans to fit your car.
Buy it here...
http://cgi.ebay.de/5Gang-Getriebe-Me...QQcmdZViewItem
mercmad6.3 is offline
    transmission swap rickscustomz W126 S,SE,SEC,SEL,SD,SDL Class 7 07-21-2010 08:03 PM
    manual transmission swap joef W124 E,CE,D,TD Class 33 08-27-2009 05:10 PM
    W108 engine swap? Danborn Vintage Mercedes-Benz 1 07-07-2005 07:15 AM
    Transmission swap dinofast W163 M-Class 1 05-23-2005 10:06 AM
    transmission in 1968 250s w108 wwong Vintage Mercedes-Benz 5 04-22-2005 06:59 AM
